My 71 Maverick Grabber
Discussion in 'Maverick/Comet Projects' started by leps66, Feb 4, 2011.
  1. leps66
    leps66 71Grabber
    Ovid, Michigan
    71 maverick grabber
    Just got the car back over to the pole barn. I also got a few more parts, a voodoo cam and lifters, a front and rear sway bar kit, 3.55 gear, and some paint. Waiting to see what torque converter I need.
  2. leps66
    leps66 71Grabber
    Ovid, Michigan
    71 maverick grabber
    Got the motor and trans pulled out of the car this weekend. Looks like I be rebuliding the trans, just a little to sparkle in the pan. Also started stripping the paint in the engine bay, got the voo doo cam in, and thats about it so far. O also got another parts list going. cant wait to have this done.
  3. injectedmav
    injectedmav Member
    Georgia
    Nice looking ride. Welcome.
  4. leps66
    leps66 71Grabber
    Ovid, Michigan
    71 maverick grabber
    Here are some pics of my progress:
    [​IMG][​IMG]
    [​IMG][​IMG]
  5. leps66
    leps66 71Grabber
    Ovid, Michigan
    71 maverick grabber
    got the paint on the motor stripped and repainted ford drk blue. I will post some pics today.
  6. Tim Wilmoth
    Tim Wilmoth Member
    Southside Va.
    1972 Comet gt
    Welcome from Virginia
  7. leps66
    leps66 71Grabber
    Ovid, Michigan
    71 maverick grabber
    Okay, this is what i have got done so for: motor and trans pulled out, motor and engine bay striped and repainted, put new oil pan-cam-valve springs-valve covers-distributor-disty hold down-harmonic balancer-and painted ford dark blue on the motor. In the engine bay its got a new ignition box, coil,16" electric fan, trans cooler, battery cables, master cylinder cover, cleaned and painted hood hinges, horn, and shock tower braces and painted the engine bay with extreme chassis black from eastwood. I also have installed a bigger front sway bar and also a rear sway bar. Also got the headers sand blasted and sprayed with vht black paint. Still to go is get my pulleys and intake back from power coating and reassemble the motor, replace the battery tray, rebuild the transmission, paint and body work, front bucket seats reupholstered, and replace the trunk drop downs. There is probably more i have done and still have to do but thats all i can think of at the moment. Thanks for looking.
  8. leps66
    leps66 71Grabber
    Ovid, Michigan
    71 maverick grabber
    here are some pics:
  9. Recrdholdr
    Recrdholdr National Record Holder
    London Ontario
    I want a 70-73 Maverick
    Nice job on the engine bay, Looks sharp and clean.
  10. leps66
    leps66 71Grabber
    Ovid, Michigan
    71 maverick grabber
    I got the motor back in this weekend. Just got to button some things up and then moving on to putting the trans back together.
  11. leps66
    leps66 71Grabber
    Ovid, Michigan
    71 maverick grabber
    What a great time this have been getting my mav done. Here is what i went threw. lifter tick would not go away so i bought another set of lifters. Still did it with the new ones. So we did some grinding and bingo there goes the lifter tick. one problem down. Next was the trans. Got it tore apart and rebulit. put it in the car no thrid. toke out the vavle boby, cleand things up some more put it back in. still know thrid. tore out the trans we had put one part in backwards in the trans. haha nice. looked at the vavle body again and this time things where jammed in good. so replaced it with my sister vavle body from her 68 mustang that we are restoring. now trans works great. another problem down. Now lets move on to the oil pressure. I had 5 lbs. took out the oil pump and it was all tore up. so we took the chance and just replaced the pump. Drove it 15 miles and spun a bearing. took the motor back out. The crank was all scratch to crap, all the bearings where shot. but the pistons, rods and walls where still really good. got all that replaced and the motor back in. And now it is running great can wait to go on the power tour. We are picking it up in Indy.
  12. leps66
    leps66 71Grabber
    Ovid, Michigan
    71 maverick grabber
    update: My 71 now has a 347 with an AOD trans, aluminum radiator, msd 6al digital ignition box, quick fuel 750 double pumper, new heater core, a Eaton Detroit Trutrac, electric fuel pump, and probably some more stuff haha.
    I am now doing the body work and some interior work. I got new front buckets from a g6, just bought a newly re chrome rear bumper and drop my front off along with the boomerangs to get redone. here is a pic of my new bumper
  13. 71gold
    did you make the power tour?
  14. leps66
    leps66 71Grabber
    Ovid, Michigan
    71 maverick grabber
    no 71gold i didnt make it this/last year.. was still working out problems with the trans. going to try and make it to some of this year dates
  15. Mel Moeller
    Mel Moeller Maverick Moe
    Twin Falls Idaho
    1971 Ford Maverick, Two 1973 Mavericks, 1974 Mercury Comet
    I have heard that some Maverick owners love their cars so much that they sleep with the parts. Now I believe it. :rofl2:
