My 72 Comet Build.....
  1. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    Got the drivers side header and the pass side tubes that were ready all welded up this week..... Finished tacking the 3rd tube on the pass side, started the 4th 3 times..... Struggling to get the length where I want it.....
    Here's a couple pic's of the driver side header.....
    Krazy Comet and RMiller like this.
  2. Xplane
    Xplane Member
    SoCal
    Lots
    Looks good Frank, love the V-band collector connection.
    franktf likes this.
  3. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    Thanks…..
  4. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    Finally had a chance to work on it a little Sun morning..... Got the last tube fitted and tacked together on the pass side header..... Just need to get the last 2 tubes welded and ready to assemble the header next weekend.....
    Some pic's of the progress.....
    [​IMG] [​IMG]
  5. Xplane
    Xplane Member
    SoCal
    Lots
    Nice work frank, what is the ET goal for the new combination?
  6. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    Thanks….. I am thinking it should run in the high 6's 1/8th mile on motor, but who knows.....
  7. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    The pass side header is all tacked together and ready for tig welding..... Also started looking at some of the exhaust stuff I have laying around.....
    Here's what the header is looking like.....
  8. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    Worked on some pieces for the exhaust today, but I really need the other header done to get anywhere with it.....
  9. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    The pass side header got all welded up this week and I managed to get a decent start on the exhaust today.....
    Progress pic's.....
  10. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    I also got my new intake manifold and carb this week(did I say carb?)….. Let me tell you, If you are going to use one of the new Holley split intakes for the LS1 you better have some hood clearance for the big bad bitch.....
    mavgrab302 likes this.
  11. Xplane
    Xplane Member
    SoCal
    Lots
    Looks good Frank, that gonna fit under your cowl hood? I surprised to see you go carb with this combination!
  12. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    Thanks, it would definitely fit under a cowl..... The flat hood that's on the car now just barely touches the front vent tube on the carb, it will have plenty of clearance with the BOSS 429 scoop.....
    Just going a little more old school for the moment.....
  13. Xplane
    Xplane Member
    SoCal
    Lots
    You plan to run O2 sensors? If so what O2 controller you gonna use? I’m still looking into it and learning.
  14. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    I am going to use a wideband because of the ethenol, just haven't decided which one yet.... If it were just gas I would rely once reading plugs.....
  15. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    The exhaust is done through the mufflers at the rear end, still need to make tailpipes but I am tired of screwing with pipe on my back right now..... Plus my shop was a grinding dust disaster between making the header and exhaust this far, it was driving me nuts and past time to clean up..... So I put the car on the ground and got it outside out of the way, then purged my the shop and car of grinding dust.....
    Here's what the exhaust is looking like so far..... Front of car is lowered to ride height and rear is approx. an inch high, there is still some good ground clearence.....
