My 72 Comet Build.....
  1. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    Today I finished installing the panels I made behind the rear seat..... Then I sealed all the joints up with some seam sealer on the interior side of the panels.....
    After that I took a ride to Tampa, had to go to the junk yard and check a Maverick the put on the lot..... I got a couple pieces I needed, but there wasn't a lot of good stuff on the car..... Too bad though because the shell actually seems to be half way decent and virtually no rust.....
    Here is the rear filler panels installed and sealed.....
  2. blugene
    Dang. Your almost done! :party5:
  3. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    I wish!!!!!:yup: I have almost put a halfway decent dent in the work that needs to be done.....:(
  4. Cruzin Illusion
    Cruzin Illusion Enigma
    Commerce City, Colorado
    1972 Grabber
    Looks amazing!!! Can't wait to see the final product.
  5. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    Me either, I wish someone would finish it for me.....:rolleyes:
  6. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    This morning I sealed up the trunk side of the seat area filler panels..... Then after picking up a little I made the exhaust to the rear end, just need to make the tailpipe next week(I put the muffler there due to the gas tank being centered I could not use the stock on beside the tank).....
    Here is the rear panel sealed up on the trunk side.....
    and here is the exhaust, so far.....
  7. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    This morning I installed a much better set of rechromed boomerangs..... Then I painted the trunk side of the rear seat firewall satin black along with the top of the package tray..... After that I started modifying a set of 1" speaker spacers to fit the front kick panels so the speakers I want to use will fit there.....
    Here is the boomerangs installed.....
    Here is the painted areas.....
    Here is the driver side kick panel and spacer so far.....
  8. mav1970
    The way you blended that ring in to the complex shapes of the kick panel look great :thumbs2:
  9. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    Thanks, I think it came pretty good..... It is really tight fitting when it is actually screwed to the panel and not just sitting on it..... Tomorrow I will get the other side fitted and get the clearance holes opened up in the front door post.....
  10. mrmalina99
    mrmalina99 Member
    Belfair, WA
    1973 Maverick
    Did you happen to take any pictures of that area with the boomerangs off?
  11. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    I did not..... I removed the old ones, cleaned the dirt out and installed the new ones.....
  12. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    Today I modified the other speaker spacer for the pass side kick panel and cut the hole in the panel..... Then I marked up the door post for the speaker clearance hole and cut them our..... I deburred those holes and scuffed the paint from the cowl all the way down to the flat of the front floors..... After that I masked up the front of the roll cage, all the holes in the firewall, around the windshield and door jambs..... Then I applied Lizard Skin to the inner quarters and to the firewall from the cowl down to the floor seam at the bottom of the firewall.....
    Here is the speaker clearance layed out, then cut and deburred.....
    Here is the firewall area masked up, then with Lizard Skin applied to it and the inner quarters.....
  13. Dave B
    I wonder what the weight of that stuff is, once it's dry...Looks awesome!
  14. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    Wet the Sound Control weighs 13 lbs a gallon and the Ceramic Insulation weighs 5.5 lbs a gallon.....
    So far I have used just over a gallon of Sound Control and almost 2 gallons of Ceramic Insulation..... That is for the undercarriage and what I have done on the inside so far..... By the time I am done I will have used almost 2 gallons of SC and close to 3 gallons of CI..... Roughly about 30 lbs.....
  15. Dave B
    Probably less than Dynamat.
