My 72 Comet Build.....
  1. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    Me too.....
    Thank you.....
    It's not that hard to make the trim work..... The Grabber end caps have the reinforcement areas where the screws go, you just have to line the trim up and drill the holes for the studs and screws.....
    Thanks guys.....
  2. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    Got things picked up a this morning and got all the under dash stuff down so I could get it all cleaned up and ready to go in..... I did get the outer casing for the Lokar throttle cable cut and in place, I will fit the inner cable once the throttle pedal is in place.....
    Here is the throttle cable housing in place.....
    Here is a couple pic's of the really clean heater box before I opened it to change the heater core and clean it up..... I will have to get a seal kit for it only because the foam has broken down on the inner heater door.....
  3. ford84stepside
    ford84stepside Lone Wolf
    Berry Alabama
    1947 Lincoln Zephyr Coupe
    When is the big motor going in? It just looks funny to see all the mods then see that little six in there. :D
  4. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    I am going to get it running with the 6 again..... I still have some suspension stuff to get for the front, also need some pieces for the turbo kit fabrication..... It's been sitting long enough, so I will drive it with the 6 while I collet everything together to do the swap and front suspension.....
  5. Mercurycruizers
    Venetia, PA
    I tried the factory spoiler on my Comet. It just didn't look right. It had the chrome on it also. I still have the factory spoiler mounted on a trunk lid for an easy switch. Had it painted when car was painted...
  6. mercgt73
    I think the spoiler works great on a Comet. But I am partial. I am indeed jealous of Frank's trim work...
  7. Mercurycruizers
    Venetia, PA
    Here's mine with the Grabber spoiler & chrome....
  8. mav1970
    That spoiler is looking down at those Comet tail lights and saying "where the hell am I" :biglaugh:
  9. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    Thanks guys, I think having the whole tail light panel blacked out makes a huge difference in how the spoiler looks on a Comet..... Between the trim and the bumper is frames the blacked out panel nicely.....
  10. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    Made some progress for a change today..... Got the firewall insulation cleaned up and installed..... Also cleaned up and installed the driver side cowl vent, firewall spacer for the brake pedal bracket, wiper motor/bracket assembly, wiper pivots/linkage and my custom heater hose fittings..... I did get the overhead switch panel installed too..... The driver side wiper pivot/linkage was a pita, when I was putting one of the screws the nut that was crimped into the cowl popped out and fell into the cowl area..... I had to fish it out of the cowl(lots of fun there), then get it cleaned up and back in place so I could tack weld it in..... After that I cleaned the area up inside and out, and got some brushable seam sealer around it in the inner cowl area..... Then I was finally able to get it bolted in place.....
    Here is my modified bulkheads for the heater hoses.....
    Here is the everything else installed in the firewall area.....
    Here is the overhead switch panel.....
  11. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    Got the seals I needed for the heater box and reassembled it..... Then I installed heater hoses from the firewall fittings to the engine..... I also put the brake pedal bracket assembly back in the car.....
    Here is the assembled heater box.....
    Here are the new under hood heater hoses.....
    Here are the brake pedal brackets installed.....
  12. ford84stepside
    Berry Alabama
    What! You didn't paint the brake pedal brackets? You're slipping Frank! :rofl2:
    Everything else looks great as always!:dance:
  13. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    Have you tried to paint any of those yet..... They spray them or impregnate them with some kind of oil/lubricant..... They do not like to be painted.....
  14. ford84stepside
    Berry Alabama
    Just yanking your chain Frank! :) Just thought it was unusual to see a rusty looking piece surrounded by new paint!:)
  15. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    I know..... I was just saying about trying to get paint on them, and I figure if there 42 years old and no worse then they are the hell with them(you can't see them when it's all together).....
