My 72 Comet Build.....
  1. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    Lapped the valves in and installed the Isky springs this morning..... The heads are ready to put on the motor now.....
    Here they are.....
  2. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    After work today I cut the mounting boss of the outside of my CS130D alt case because they loo like shit if you do not need them(I have done this a couple times on customers LS swaps we have done where this boss is not necessary for the aftermarket drive systems)..... Then I got it mounted on the motor with the new low mount alt only bracket I got earlier..... I also got some nice ARP Stainless hardware for the new bracket.....
    Here is the boss I am talking about and it being removed.....
    and here is the alt mounted on the motor.....
    mercgt73 and Krazy Comet like this.
  3. Krazy Comet
    Dismal Swamp
    Schweet!!! Nice work...
    franktf likes this.
  4. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    Thank you sir.....
  5. bkcha
    bkcha Member
    Pooler, GA
    71 Gabber
    Looks great but will it clear the frame with the motor in??
  6. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    Thanks..... It should just clear when extended all the way out..... If I have to put a small notch in the frame, no big deal.....
  7. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    Been working on the motor some more week after work..... Got the head studs installed, heads on and torqued, rocker arms/push rods on and torqued..... Today I got the valve cover and an steam port fittings on..... I also checked the fit of the after market valley cover and intake manifold so I could lay out the steam port manifold I want to make(more on this later).....
    Here is the motor progress since Monday.....
    Tannersg1 and mercgt73 like this.
  8. mercgt73
    mercgt73 Member
    Awesome! Coming together nicely, Frank.
  9. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    Thanks again, Rusty.....
  10. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    This morning I made the steam port manifold(just need to put mounting holes in the bottom).....
  11. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    I got the call, he showed up. he heard, he paid, we pulled and he went on his way......
    The straight 6 is gone.....
    Paul Masson likes this.
  12. mercgt73
    mercgt73 Member
    Flintstone power!
  13. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    It might be faster with Flintstone power then it was with the all mighty 200 straight 6..... :biglaugh:
  14. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    No progress made today, had to clean up the shop after the speedy motor/trans removal yesterday..... I also flushed the heater core and drained all the gas out of the car.....
  15. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    Once again, I have been working on it a little this week after work..... Got the steam port manifold mounted on the valley cover and the assembly painted..... Installed the valley cover on the motor, also bolted the coils on the valve covers..... The fittings came in Thursday for the steam port manifold and I got the installed..... We were out of 1/4" stainless tubing at work, so I need to get some so I can get the lines made.....
    Here are some pic's of the progress, the last pic is with the intake just sitting in place.....
    Tannersg1, kboldin and Bad Brad like this.
