My 72 Comet Build.....
  1. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    I went down to the shop and unmasked it after the Nascar race was over..... It's looking really good..... It was dry to the touch but not completely dry yet.....
    It is quite a bit darker then the firewall that was painted with the same paint a little over a year ago..... I think it will look fine once the rest of the paint dries and gets a little age on it, I think the firewall will also darken up a little if I clean it real well.....
    Here you can see the difference in them.....
  2. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    Today I put all the bulkhead fittings in the front of the car..... Then I made the stainless trans cooler hard lines that go in the outer fenderwell from the core support to the back of the tower on the driver side..... Next I made the stainless brake line that goes from the engine compartment bulkhead down to the union on the side of the front subframe..... Last thing I got the fuel feed and return braided hoses routed through the torque box to the bulkheads in the front of the driver side tower.....
    Here's the trans cooler hard lines, you can also see what I got done on the fuel lines today(still need to get the retainers on and finish routing them to the rear)..........
    Here's the brake line.....
    JoeB likes this.
  3. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    Got a little more done today..... Modified some Billet Specialties hose separators so I can use them for hose retainers, put 2 on in the inner fender area using riv-nuts to hold them..... I put a couple vinyl lined clamps on the trans cooler hard lines..... I also put the motor mount bushings in the k-member and bolted it in the car..... Then I put the car up in the air a little higher so I can get the fuel lines attached to the underside next weekend.....
    Here is todays progress.....
    CaptainComet and mercgt73 like this.
  4. CaptainComet
    And I got to see it in person yesterday! :thumbs2:
    I really like the paint in the engine compartment. It has a little bit of texture to it.
    franktf likes this.
  5. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    Thanks, It was good to see you too!!!!! I texture the chassis coat partly because I like the look and it makes the paint much more durable..... I did the same on my last car, and if you dropped a wrench or something else it didn't chip the paint.....
  6. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    Today I got the fuel lines run all the way back to the bulkhead fittings where they go into the trunk..... Also mounted the fuel filter..... Then I cleaned up and put the car back down some so I can get the front suspension/steering back in the car tomorrow.....
    Here are progress pic's for the fuel lines from front to rear.....
    mavgrab302 and mercgt73 like this.
  7. COMETIZED
    COMETIZED Member
    Florida
    70 Mav. 74 Comet
  8. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    Thanks Chip.....
  9. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    Today I got most of the front suspension in(I broke a bearing plate for the top of one strut one of the 100 times I put the front stuff together when building the front suspension)..... I did manage to get the master cylinder, steering column and shaft all installed too.....
    Here is the broken bearing plate(I will get the replacement parts this week).....
    Here is the progress made today.....
    mercgt73 likes this.
  10. mercgt73
    mercgt73 Member
    Going back together! I'm excited to watch! Looks amazing, Frank!
  11. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    Thanks..... Yeah, its nice to know I am putting stuff on that is going to stay on.....
  12. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    I got the part I needed for the drivers side strut this week so I was able to get it installed this morning..... I got the steering wheel centered to the rack and pinion center..... I also got the firewall feed for the wiring installed, then mounted the line lock and started on the brake lines..... Hopefully I can get the front brake lines made and installed tomorrow.....
    Here is the progress for today.....
  13. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    Today I got the brake lines from the master to the residual valves and the drivers side front from the line lock to the brake hose bracket..... Also figured out what I need for front brake hoses.....
    Here's todays progress.....
  14. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    Today I made the last brake line and got it installed..... The new brake hoses came this week and I installed them too..... I put the rear up on stands and removed the rear tires so I can bleed the brakes in the am.....
    Here is the last front brake line before final install.....
    and here is the rest of the progress for today.....
    Paul Masson likes this.
  15. tody
    tody Member
    cologne, germany
    is it just me, or doesn't the front brake hose look rather short?
