My 72 Comet Build.....
  1. COMETIZED
    COMETIZED Member
    Florida
    70 Mav. 74 Comet
    Yep ! Understand .. The last four cars we've done we put all new wiring Under the Dash, Under the Hood , and from Front to Rear .. New fuse boxes , relays , sensors and safety items like a Red Light that will appear if there is a problem with Overheating , or Low Oil Pressure etc. I also installed ' override ' switches on the dash that if ever required I can activate the fans which will provide cooling while the car is " sitting " and not running. I've never had to do this but it's there if I need to . I'am a fan of the Hot Rod POWER TOURS and on almost ALL of the tours I've attended there were Looooooong periods of time when the car was idling ' in line ' to enter the venue locations. So far none of the cars we've prepped have had an overheating problem and that's with our AC running . We put Pusher AND Puller Fans and it seems to help greatly. Looking forward to seeing your ' completed ' Comet at the NPD event in Ocala.FL.
    I'm sure it will look even better than your pics.
    Cometized
    (Chip)
  2. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    Thanks Chip..... I just registered for the event a little while ago.....
    mavgrab302 likes this.
  3. COMETIZED
    COMETIZED Member
    Florida
    70 Mav. 74 Comet
    That's great news .. Looking forward to seeing you there . We should have Kim's Maverick finished by then so we'll
    have two Mavericks and one Comet this show. I hope we have good weather for the event..I understand that it's been changed to be ONE DAY ONLY ( Saturday) ..It previously was Two Days Saturday AND Sunday and if anyone WON a trophy on Saturday if they weren't PRESENT on Sunday .. the trophy went to the guy UNDER them, and if THEY weren't there it was handed ' down ' until someone was actually THERE at the presentation. I won twice in the past and didn't receive the trophy because I didn't attend Sunday .. Bummer ! .. Anyway It's a Great Show and I always enjoy checking out the other fine Mavericks and Comets along with the OTHER Fords ..
    See ya then hopefully,
    Cometized
    (Chip)
  4. COMETIZED
    COMETIZED Member
    Florida
    70 Mav. 74 Comet
    Hi Frank:
    Read your post about keeping the Taillights .. I don't know if you seen the post earlier on SEQUENTIAL LED
    Taillights for a COMET that are now available. I have a set on my Comet and they are great . The taillights were a real ' Hit ' on the last Power Tour I made. The people that have these are EASY PERFORMANCE in Wyoming , Michigan .The guy to talk to is " Jim " and their phone number is 616-214-7880 if you're interested.
    Cometized
    (Chip)
  5. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    After a good and needed shop cleaning this morning, I got a new Monte Carlo bar made..... There wasn't a lot of room to get through between the throttle body and the hood, It's a got at least 1/4" of clearance over the throttle body and almost 1/8" to the hood..... I also gave the car a good wipe down, it was getting quite dirty.....
  6. cool70mav
    cool70mav Member
    New Orleans
    had 1969.5, 1974 Maverick 2008 Shelby Gt Mustang 71 Lime Green Grabber
    That looks tight. Love what you are doing. I really like the fact the shock towers still look stock . I think you are doing a top notch job on your Comet. Thanks for sharing your build Tommy
  7. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    Thanks, glad you like it.....
  8. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    I made so brackets to hang off the Monte Carlo bar to mount my breather cans for the motor..... I also got a ethanol sensor this week, I think I know how/where I want to mount it but I need to get a couple fittings this wee to make sure it will work out..... I am also trying to figure out how/where to mount a water/meth tank.....
    Here's the brackets on the Monte Carlo bar and the ethanol sensor I got(it the one Holley recommends in there V4 software.....
  9. mgabski
    mgabski Member
    1973 Maverick
    Hey frank, I was on theturboforum, noticed you had a build for your old grabber. You don't happen to have a photo album of that car do you? I was trying to look back at the turbo set up you ran for inspiration.
    Thank you.
  10. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    Sorry but I no longer have any photos for that build, I removed them from photobucket and shortly after that I had a computer burp the lost all my photos..... I was lucky I had this build backed up on a separate drive.....
  11. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    I got the fittings I need this week for the ethanol senor..... Today I mounted and plumbed everything back up..... I do not have a good place to mount a decent size water/methanol tank under the hood, so I decided to go with a trunk mounted tank..... I had to remove the rear seat again to I can routed the hose and necessary wires for the pump and level indicator..... I also went through my wiring stuff to see what I need to get coming, getting closer to wiring it.....
    Here is the ethanol sensor mounted.....
  12. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    Last Sunday I got the wires and tube for the water/methanol ran and put the rear seat area back together...... I got the 2.5 gallon water/methanol tank this week, unfortunately the area of the trunk that I have to mount the tank is not flat so I figured out how to make a mounting bracket for it(I will get it made this week)..... I am still waiting to get the Monte Carlo bar and other stuff back from powder coat, so I couldn't button that stuff up yet.....
    I did however start planning out my wiring harness..... I got a harness made and in place for the overhead switch panel(still need to configure the under dash end of this herness, I also put the 4 gauges in the center of the dash.....
    Here's some pic's of the gauges mounted and the switch panel wiring.....
  13. cool70mav
    cool70mav Member
    New Orleans
    Looks awesome hope you can put a video of it running when you are finished. I really love what you did with the shock towers. That was a great idea. I love the stock look but yet enough room for everything. Keep up the awesome work
  14. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    Thanks.....
  15. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    I got some mounting brackets fabed up this week for the water/methanol bottle and pump..... I had to do a little tweaking on the bottle mount, but I got them both mocked up in the car and I am pretty happy with them..... They still have to be painted before getting installed.....
    I also made a harness for the trans, got connectors on everything underneath and hook it all up..... The harness routes through the old speedo cable grommet and up through the instrument cluster hole..... I still need to connect everything under the dash..... That will come soon enough, I am just trying to get the harness legs made up and in place.....
    Here's some pic's of the progress.....
