My 72 Comet Build.....
  1. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    Went over housing, remove any weld spatter and cleaned housing again..... Painted housing..... Tapped abs sensor hole and plugged it, drilled and tapped for vent fitting..... Next weekend I will make some new brake lines, hopefully get it assembled and in(we shall see what happens.....
    CaptainComet likes this.
  2. COMETIZED
    COMETIZED Member
    Florida
    70 Mav. 74 Comet
  3. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    Well, not much progress was made last weekend..... I did get the gear set up, but I will have to reset the pinion depth because it's a little too deep in the pattern..... Hopefully I can get it finished up and back in the car this weekend.....
    Here's a couple pic's of the mostly non-progress.....
  4. mojo
    Where u get the brake T-Fitting on axle housing? I have a slow reduction in brake fluid front half of my master cyl. I have pulled rear (drums) wheels - no fluid loss. Master new last year - I have a little wetness around the axle housing, thinking that may be the problem. I dried the housing but have not had chance to look there since. Going to look nx week when I get the car up for new ex. header install.
  5. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    No progress with the gear last weekend, no matter what I tried I could not get a decent pattern on it..... After I bailed on setting the gear up I did get the bearings on and studs in the axles, then put them in the housing and assembled the rear brake components.....
    I ordered in another gear this week..... I went ahead and made the brake lines for the rear first thing today..... Then I set up the new gear with no issues what so ever, good looking pattern on this one..... I put the rear cover on and got the rear bolted in the car..... Then I checked to see if the driveshaft would fit, not a big surprise it didn't..... It actually bolted in but only has 3/8" clearance on the trans output shaft, to close for sure..... I will get that taken care of this week, at least I can just get it shortened.....
    Here's the progress.....
  6. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    I got this from work, It was in some stuff for an old project and I have no idea where it came from..... The only part number on it is for the Parker fitting it was on.....
  7. mojo
    Thanks for the response!
  8. schroensr
    Berkeley Springs,WV 25411
    1975 Mercury Comet
    looks like my first car.
  9. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    Got everything all bolted in, brakes on and bled..... I have 1 little mod to do on the exhaust and I'll get the drive shaft shortened this week, then we should be ready to go again.....
  10. mavgrab302
    I hope to see you in January for the NPD show...
  11. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    Already registered, just received my conformation card yesterday..... So I will see you there.....
    mavgrab302 likes this.
  12. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    Finally all back together..... Went through the gear break in cycle, drove it around some Sat and Sun to put it through a couple heat cycles..... Everything seems fine so I reset the cal-tracs and recheck the front end alignment..... I'll probably drive it a some the beginning of the week and get it back out to the track on Wed nite!!!!! :victory:
  13. CaptainComet
    The car was so "sleepy" until you put those beadlock wheels on it. You aren't fooling anyone now ... lol.
    Love it!
    Rasit likes this.
  14. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    I imagine when you hear it that might give it away too.
  15. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    Got it to the track Wed nite..... She leaft harder then ever right up to 1 sec into the pass when it had a catastrophic planetary failure..... It only had a rebuilt 1.76 planetary set, but I still find it hard to believe it gave up off the footbrake..... It leaft on 3.5lbs and was at 18.6lbs at 4 tenths into the hit, it was going to be a good run.....
    Here is the carnage.....
