  1. rag9836
    rag9836 1972 Comet, 67K
    Riverside, CA
    Comet
    Any updates on this build?
  2. mercgt73
    mercgt73 Member
    Next week’s plan.
  3. mercgt73
    mercgt73 Member
    Before I can cut out the towers, I thought I should repair the aprons first. Used Joe’s apron repair kit to get them 90% there. Just need to finish around the hinge mount areas.
    TeeEl likes this.
  4. mercgt73
    mercgt73 Member
    No going back. Towers removed, body leveled up.
    William623 likes this.
  5. mercgt73
    mercgt73 Member
    MII mocked up and measured. Fits great. Then tacked in place. It was a fun day off!
    Krazy Comet and mojo like this.
  6. Krazy Comet
    WoW, serious stuff....
    mercgt73 likes this.
  7. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    Whose suspension did you go with? Looks like a nice kit.
  8. mercgt73
    mercgt73 Member
    Full Tilt Street rod. I like there Ford in Ford lower control arms design.
    https://www.fulltiltstreetrods.com/
  9. Tannersg1
    Tannersg1 Member
    Classified
    Very nice!!!! So do you have to keep that original cross member in when you go to a Mustang II suspension?
  10. mercgt73
    mercgt73 Member
    I think technically you can remove the original strut rod support once the MII is installed. I’m going to leave it unless it gets in the way.
    Tannersg1 likes this.
  11. RMiller
    Kennewick, WA
    I'd leave it too, I use it to jack the front of the car up.
    mercgt73 and Tannersg1 like this.
  12. RMiller
    Kennewick, WA
    Looked at the control arms, that's a slick set up.
  13. William623
    Orlando
    1973 ford maverick grabber
    Looks like it fits very nicely. Honestly the quality appears fantastic and that seems to be one of the best priced kits around.
  14. mercgt73
    mercgt73 Member
    Measure, measure again, check square, check level, measure again. Hats and crossmember tacked in place. Next is finish welding everything in place.
    adam 72 and Russell like this.
  15. JosephBrand
    JosephBrand Member
    Munford TN
    1975 maverick
    any updates?
    71gold likes this.
