My cousin's 71 Mav project...
Discussion in 'Maverick/Comet Projects' started by chirt, May 23, 2010.
  1. chirt
    chirt Carlos Hirt
    Massachusetts
    I know, He had been expecting your visit. :yup:
  2. mojo
    Great lookin resto. I am filled w/ envy. I guess it makes a difference when ur in the automotive business. Anyway, Junior has my vote - I wud love to see that car in person.
  3. chirt
    chirt Carlos Hirt
    Massachusetts
    Well, come on down! you're only about 1,000 miles away! :drive:
  4. mojo
    A thousand miles>>>>>Guess I'll have to settle for pictures. ;)
  5. Ryan
    Ryan Ford Addict
    Phoenix Az.
    Is that Mustang crosmember holding the T5? What kind of modification did it need? Looks maybe shortened a little. Looks like it fits nice and has good exhaust clearance.
  6. chirt
    chirt Carlos Hirt
    Massachusetts
    Yes, It is.. We drilled the tunnel's cross member inserted then welded a 1/2 inch O.D or smaller pipe I don't remember now.. through the cross member and then used a long bolt to go through both c members. The mustang's cross member had to be tweaked a little bit at the ends
    I hope you understand my writing :p
  7. Ryan
    Ryan Ford Addict
    Phoenix Az.
    had to use the pipe to set the crossmember back farther or just not wide enough mounts on the frame? Or maybe both.
  8. chirt
    chirt Carlos Hirt
    Massachusetts
    No,no.. the pipe is going inside the Mave's cross member or box frame that goes around the tunnel. It's there to serve like a bushing so the the box frame don't get crushed when tightening the X member.
  9. Ryan
    Ryan Ford Addict
    Phoenix Az.
    Ok so see if I get this right. You are mounting the mustang crossmember on the back side of the maverick crossmember mounting box thing. Just using the tube to reinforce the hole that the long bolt will go through. So the only modification was to change the angle on the crossmember ends to meet up with the tubes. Basically moving the mount back the width of the original mount box thing. I see you used the SN95 crossmember, wonder if the Fox crossmember would fit better and not need to be modified on the end. Gonna track one down and give it a shot. Better tha nstarting from scratch with a mount.
  10. chirt
    chirt Carlos Hirt
    Massachusetts
    you got it! from what year T5 are you using?
  11. Ryan
    Ryan Ford Addict
    Phoenix Az.
    Not sure what year it was from. It is a World Class T5.
  12. chirt
    chirt Carlos Hirt
    Massachusetts
    It should say the year on the case. It might have like a little clock stamped on it and a number inside like 87. the t5 on the sn95s are about 1 inch longer then the earlier models so that will change the position of the cross member. For example in my car I have a foxbody t5, in that case It was easier to modify the maverick's crossmember.
  13. GrabberGT
    GrabberGT Chris
    Fort Worth Texas
    72 Grabber 302
    The 94-95 T5's have longer input shafts and will need to have the correct bell housing. I was told they are 5/8" longer. (Just enough to be a pain :mad:) You will likely have to shorten your drive shaft also.
  14. chirt
    chirt Carlos Hirt
    Massachusetts
    When playing around in my cousins car we compared the two t5s and his was 3/4 inch longer with the bell housing and the bearing on the back of the crank-shaft is also smaller.
    so if you have a 94-95 t5 and want to install it on an older engine that bearing will have to be replaced for the new style.
    and yes, we did shorten the drive shaft.
  15. Ryan
    Ryan Ford Addict
    Phoenix Az.
    Well I know it is out of a fox Mustang, just not sure which year. I'm already running an AOD so I don't think I will need to do anything with my driveshaft.
