My engine rebuild
Discussion in 'Technical' started by h2o, Feb 21, 2011.
  1. h2o
    h2o Mad Mav Man
    mexico city
    1973 ford maverick gt 289 v8
    Thanks for the encouragement I'll keep at it!
  2. Awesome_X
    Awesome_X Member
    Oklahoma
    I enjoy watching peoples builds, keep up the hard work. Looks like you're coming along nicely:tiphat:
  3. Blown74
    Blown74 Member
    Va
    74 302 blown- 68 Shelby Gt 500- 69 Cougar XR7 428 ram air
    Dial 1
    no other english message
  4. h2o
    h2o Mad Mav Man
    mexico city
    here's a photo of all the pistons, look at all that charcoil! obscenely rich mixture maybe?:rofl2:
    and then there's the hulk, not much to look at really, never liked the original all black look of these engines.
  5. h2o
    h2o Mad Mav Man
    mexico city
    here are pictures of the timing chain, and the crank.
  6. h2o
    h2o Mad Mav Man
    mexico city
    when cleaning the pistons i found out the were from a 302, so it turns out my 289 is really a 302?!
    then there's the new timing chain, and cylinder polishing.
  7. maverick75
    Measure a rod. That will tell you if you have a 302 or 289. They used the same piston.
  8. baddad457
    Ditto. But you only need to check the forging numbers to differentiate the two. C80E is a 302 rod, 289's were (if I'm not mistaken) C3OE. The crank numbers will tell too.
  9. baddad457
    That build up is normal for a high mileage engine
  10. baddad457
    This here folks, is a prime example of what many here hope to find in an engine block. This is the Mexican 289/302 block. Note the thicker main caps. OOOPPS, the link to those pics didn't make it here.
  11. baddad457
    Note the odd looking water pump and crank pulley. definately not what you find up here in the states.
  12. Ryan
    Ryan Ford Addict
    Phoenix Az.
    SHouldn't the dots on the timing gears be lined up when installing, Or did you already turn the crank over by hand after installing the timing set?
  13. 74 GRABBER
    74 GRABBER Member
    Peoria AZ
    1974 grabber, 1995 mustang GT, 1967 mustang coupe, 1956 Caddilac sedan Deville
    Looks great, I do have a question though.............. Did you check the valve springs by testing pressure or did you just look for no broken or cracked springs?
    Reason I ask is I highly doubt any high mileage valve springs still meet the required pressure.
  14. h2o
    h2o Mad Mav Man
    mexico city
    Actually I didn't check the pressure since the springs had something like 2500 miles, practically brand new, I did check for cracks though, found none.
  15. h2o
    h2o Mad Mav Man
    mexico city
    Yes they do but this was a test to see if it fit. Of course if you already have the engine mostly disassembled you can easily line the dots.
