My first -AN and braided stainless experience
Discussion in 'Technical' started by scooper77515, Apr 22, 2007.
  1. Ryan
    Ryan Ford Addict
    Phoenix Az.
    I feel your pain. My fingers hurt just thinking of doing this again.
  2. ShadowMaster
    ShadowMaster The Bad Guy
    The ShadowLands
    1969 1/2 Maverick
    Actually Scott...you can plumb the whole damn car with braided line and NHRA won't give a chit. It is the rubber line that they don't like.
    Also, I use duct tape instead of electrical tape. Holds the strands better. We use Marvel Mystery Oil for assembly instead of motor oil.
  3. don graham
    i gave up on the braided line. nhra has approved hi pressure rubber line and it's so easy to work with. i love it. and you can use as much as you want. :)
  4. Rick Book
    Rick Book Member
    Thailand
    Missing my old '70 Maverick
    I'd rather spend that 75 dollars on something more important.
  5. don graham
    $75 is cheap to save all the fingers.:clap:
  6. blugene
    I been messing with braided line also, only not high pressure stuff.
  7. stmanser
    Davenport, Iowa
    you know.. you all make it sound so easy
    i think i am gonna invest in that tool... got a part number>?
  8. Andysutt
    Andysutt '72 Comet GT
    Conway Arkansas
    1972 Comet GT
    Tool looks cool.
    Id suggest the -6 for tranny also. I just happened to get a good deal on the -4 that I have
  9. PaulS
    Do not use soft lines on the tranny cooler lines. Use metal for as much of it as you can. Rubber lines have a lot more internal friction and the pressure in those lines is needed to lubricate the rear of the case. Metal lines are also less likely to get damaged and leak all your oil onto the ground.
  10. scooper77515
    OK, dummy question here...
    How do you say or pronounce "-6AN"?
    So if I go to the store, what do I ask for instead of "3/8 AN"?
    Is it "negative -six", "dash-six", "ought-six", etc...:huh:
  11. NAFORD302
    NAFORD302 Member
    SILEX MO
    77 FACTORY V8 AC CAR
    6an How Are Your Hands Do They Hurt
  12. Andysutt
    Conway Arkansas
    1972 Comet GT
    Dash 6 AN line/fitting
  13. scooper77515
    I only got poked once. That was when I was trying to lay the braid back down after it flared up with the dremel cutoff tool. After I used the cable cutter, no problems at all.
    I consider this a successful and pain-free project(y) (see? no bandaid on my thumb:D )
  14. NAFORD302
    NAFORD302 Member
    SILEX MO
    What Kind Of Cable Cutter Tell Me More I Need To Do My Fuel Line
  15. stmanser
    Davenport, Iowa
    not too bad.. if it works good
