my latest project...
Discussion in 'Technical' started by 71gold, Dec 25, 2019.
  1. 71gold
    been doing a little clean up wiring under the hood, still have a little to go. replumbed the fuel regulator, shortened up some hoses and installing a one way check valve (EFI). got the new throttle/kick down cable bracket mounted.
    got the new air breather modded and ready to install. went with the ...breathable top. also had to lower the deep drop base bottom plate.
    to do that "I" had to cut .250" off of the mounting ring, then cut a slot in the base for the throttle linkage to go up into the base .125" (slot is sealed). then drilled a .750" hole in the base to put a rubber grommet in for an air temp sensor. all this took longer to type than for Harold to do...LOL
    I did the filing and sanding of the edges...:whew:
    all this was prep for the new...Pro Flo 4 multi port fuel injection system...
    to be continued...:outtahere:
    mavgrab302 likes this.
  2. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
    I love that air filter. What is it?
  3. 71gold
    Summit 14" top...K&N "filter... aftermarket deep drop base .
  4. Jaybee
    Jaybee Member
    Hampton Roads, VA
    1974 Maverick
    Nice setup!
  5. 71gold
    thanks...
    I think I will like the bluetooth app that runs everything. it comes with a 7" tablet but I have the controller loaded on an app on my phone.
    a friend has this setup on a 5.3 on a run in engine stand, that's what sold me on the idea. he can walk 30 yards up his driveway and still use the controller...:thumbs2:
  6. bmcdaniel
    Just in case something blows up? LOL
    71gold and mojo like this.
  7. Maverick_Ian90
    Maverick_Ian90 Member
    Northeast
    1975 Ford Maverick Grabber
    Bluetooth app for FI? Now that's interesting.
    71gold likes this.
  8. mavgrab302
    I've been eyeing the Pro-Flo 4 for a while now. I only know of one person using it on his mav, and he likes it..
    71gold likes this.
  9. 71gold
    finished up the wiring cleanup project. got the new relay for the E-fuel pump installed, relocated the relay for the E-waterpump and the Volvo relay for the Volvo fan... all is working...:thumbs2:
    going to try and get the EFI plugged in and fired up next week...:drive:...:chirp:
