My "new"72 Mav bracket project
Discussion in 'Maverick/Comet Projects' started by Paul Allen, Nov 18, 2014.
  1. Paul Allen
    Paul Allen The Maverick is back!
    Middleburg Florida
    1972 Ford Maverick
    I am planning on running at Gainesville raceway. Also they just opened a new IHRA member track in Green Cove Springs which is close to the house. The track owners are putting a lot into it. I will probably run there a lot also. If I can remember how to drive, and am somewhat successful at ET racing again, I may enter into some of the IHRA divisional events. I have a friend I help in Top Sportsman, I would love to take my car along to some of these events also. It would be a lot of fun. We ran last year at the IHRA event in Bradenton, down close to you... it was a great event... lots of fun.
    That's my game plan anyway.
  2. CaptainComet
    If you get down to Bradenton, let me know.
  3. mavgrab302
    I used to go to Gainesville every Wednesday and watch... let us know when you'll be there, its only 40 minuites from the house...
  4. Paul Allen
    Middleburg Florida
    1972 Ford Maverick
    Will do. I am hoping to get the car on the track for initial tuning and shakedowns by mid summer. I will let you know when I get it running and to the track.
  5. stroker mav
    stroker mav Member
    canton, ohio
    1964 country sedan,1933 essex terraplane
    Hi, Paul the cars looking good hope you get to here it fire up soon . Where leaving for florida in the morning,talk to you soon. Mark
  6. Paul Allen
    Middleburg Florida
    1972 Ford Maverick
    Got the 347 just about ready to run. Plumbing and fuel lines are completed. Transmission 100% and new custom driveshaft has been installed. All I have left is to wire it up and run.I have not had a chance to post pictures in a while. Here are some pics of the progress. IMG_0326.JPG IMG_0326.JPG IMG_0325.JPG
    CaptainComet likes this.
  7. fuelish351
    fuelish351 Member
    San Jose, CA
    73 Maverick Grabber 2.3 Turbo
    Is that the popular ranger brake master cylinder I see? I like your feul cell install
  8. Paul Allen
    Middleburg Florida
    1972 Ford Maverick
    More pics to share of the car.. Some of the drive train and trunk
  9. Paul Allen
    Middleburg Florida
    1972 Ford Maverick
    Fuelish, ...Jegs racing universal master cylinder. I thought it was a pretty trick piece. It has the larger bore for My Wilwood disc brakes. Plus a optional bracket kit to mount the line lock underneath the unit. I had to do some custom line work, but I thought the brakes came out pretty good. Plus it bolted in place of the stock one with no mods.
  10. Paul Allen
    Middleburg Florida
    1972 Ford Maverick
    More pics.. the car actually made it out of the garage for a while. At least long enough to clean a little bit.
    I hope to have the engine running within a week or two. I will post video when that happens... getting excited.
    Krazy Comet and CaptainComet like this.
  11. mav1970
    I see you are using a plastic cell, which is the same as mine - did you add a sump to the cell and how did you seal the rear full line fittings going through the cell - mine is a Jaz 16 gallon cell and has a textured surface on the outside of it and I was concerned with the fittings leaking :tiphat:
  12. Paul Allen
    Middleburg Florida
    1972 Ford Maverick
    Bob,
    Mine has a sump area built into it. I think it is a Jaz product also, although an older one. It has two fittings on the bottom, which is pretty standard I think. The fittings use a nylon o-ring on the inside of the cell to seal it. I believe there is also one on the outside, but like your cell, the outside is a wrinkle finish. I think the main sealing actually occurs on the inside, which is a very smooth finish. If you remove the foam in your cell, you should be able to easily access the fittings and check or replace them.
  13. Paul Allen
    Middleburg Florida
    1972 Ford Maverick
    A couple pics of the cell, I thought I had a close up of the cell itself, but maybe these will help..
  14. mav1970
    Did you get the fittings with the cell or did you purchase them? My is a 16 gallon circle track cell that pulls the fuel out of a top fitting but, now I am running an electric pump, I didn't want the pump to have to "pull" the fuel up the internal hose. I may need to find 2 of these fittings.
  15. Paul Allen
    Middleburg Florida
    1972 Ford Maverick
    Bob
    Mine came with the fittings. But you should get some AN-8 bulkhead fittings. That should get you going except if you get the tank really low in that case a sump would be helpful. As long as you position them near the bottom you should be good to go.
