My new 77 Maverick project.
Discussion in 'Maverick/Comet Projects' started by Evnldr, May 27, 2017.
  1. Evnldr
    Evnldr Member
    Delaware
    1977 Maverick
    Short back story:
    My friend and his dad started this project when he was starting to get sick.
    Now he has passed on we want to finish the job.
    So it had a v6, than a 289. Now his father got a 302 he said it was out of a 1990 - 1999 ish motor and trans from a Ford expedition, his dad said it was the same as the mustang. It was running as a 289 Now I don't know what is needed to upgrade from a 289 to a 305. Car looks rust free mostly. I have not gotten to into the car. I will add a pic not sure what is what. I'm used to newer cars. so the electronics I will need help with.
    In this pic i have circled the parts I have no clue what they are.
    Thanks in advanced..
    A is what I have no clue about.
  2. Krazy Comet
    Welcome, you can find out everything you you need to know & more(yeah here it comes)
    No Maverick ever had a V6 & Expeditions never used a 5.0... Explorers used a 5.0 from '96-'01 but the '97-up heads have a relocated spark plug so most headers/exhaust manifolds won't fit, plus Explorer headers won't fit Maverick(they are junk anyway)... Also the transmission is computer controlled(as well a engine), so without the original electronics or aftermarket controller the transmission will be dumb(in other words, won't shift)...
    Not 100% on the wiring but normally the feed to headlight, horn, windshield washer and power feed to inside of vehicle are in that area... The starter relay & voltage regulator are same as on about any Ford vehicle from '65 to 85-ish..
  3. Evnldr
    Evnldr Member
    Delaware
    1977 Maverick
    I'm now hoping he has a AOD trans, I hope to ger pics of the block /heads soon.
  4. Evnldr
    Evnldr Member
    Delaware
    1977 Maverick
    As far as the V6.. I'm going off what i was told. Most of the parts were bought years ago. my first day into this was last night, I thought the Exp had a 5.4
  5. Evnldr
    Evnldr Member
    Delaware
    1977 Maverick
  6. 71gold
    :Welcome:...:Handshake:
    AOD will work...AODE is a different story.
    was the 289 ever running/driving?
