My New GRABBER Taillight Prototypes
Discussion in 'General Maverick/Comet' started by Acornridgeman, Dec 20, 2005.
  1. Yellow72Mavrick
    Yellow72Mavrick Banned
    Memphis, Tenn.
    1977 maverick 2 door ( my sons) 250 c4
    Bravo...well done...you did a great job...put those bad boys to work.
  2. Earl Branham
    Lugoff, SC
    Eric; very nice. Gonna be neat on the car. Take lots of pics!
  3. fan2488
    fan2488 Member
    spring,TX
    1969.5 maverick, 1972 grabber
    very nice job eric. if mine taillights wanst already done. i would have to copy you.
  4. Acornridgeman
    Wisconsin
    Thanks all for the great feedback on the lights!
    Ron, will be using the THUNDERCAT brain box made in Canada!
    Dennis, this by far was the biggest challenge in the project. I tried about dozen different things on a bunch of scrap pieces. From simple solders and low heat brazing with special aluminum rods to gas welding with filler. Every time either it would not stick or it melted the trim in microseconds. I then tried the various epoxies like JB Weld and permatex epoxy products. I had great success with these "cold welds". What I found to be the best, was a clear epoxy from Permatex combined with a postage stamp sized piece of fiberglass cloth. Before application I would roughen up the inside of the trim with a course Dremel tool wheel. It is a very strong joint with the fiberglass cloth in the epoxy resin. It will bend way before it will break!
    Craig, that picture doesn't show the studs very well, but there are 10 of them for each side, so mounting will be solid! The weld actually runs into and around the stud, that is why the welds look all crooked from the overhead shot. Here is an angle shot.
    Thanks again for everyones comments.
    Eric J :drink:
  5. Tim Wilmoth
    Tim Wilmoth Member
    Southside Va.
    1972 Comet gt
    SWEET and very different ,yet will retain the stock look. I like em!!!!!!!
  6. CornedBeef4.6L
    CornedBeef4.6L no longer here
    no longer here
    pretty cool!!!!!
  7. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    I crudely simulated some other options for folks that might be inclined to do this.
    Personally, I like the one with the reflector section replaced by another lighted section... IMO it gives the most bang for the buk with sequential lighting.
  8. NICK DOMINICK
    Burke, Virginia
    Eric, That is gonna look good on your car. Very nice job and a good idea. Did you just use body filler on the bezels to smooth them out?
  9. Mavaholic
    Just a suggestion: Ever think of removing the reflector next to the back up light to make the 3 red lenses more uniform in size?
  10. Mavaholic
    Guess I should have looked at the posts on the second page before I posted that last one.
  11. Acornridgeman
    Wisconsin
    Yes, I thought about. But then the thought of some idiot rear ending my car because it had no reflectors while parked at night made me decide to keep it.
    I like all the photoshops! The Johnson Taillight Company can have many variations ! :clap: :biglaugh:
  12. ratio411
    ratio411 Member
    Pensacola
    That is a valid point, if you are in the habit of night parking your where it can be hit!
    I guess you could still take the reflector and put it in it's own section, rather than combining it with a lighted section. I guess that would be the trick for uniform sizing of the segments.
    Dave
  13. Acornridgeman
    Wisconsin
    Hi Nick, I very carefully matched all the joints and used a disc sander to square them up. The lines are very tight and I just used a small amount of JB Weld to fill them. High solids primer did the rest. They are almost invisible.
    One of the original pictures shows them right before painting with the lines all prepped.
  14. Acornridgeman
    Wisconsin
    Trouble is you run out of space. These are 25" long and there is only like 27" between the gas cap and the end of the tail panels raised area. :rolleyes:
  15. Mavaholic
    Time to shave off the gas filler. :D
