My project progress
Discussion in 'Maverick/Comet Projects' started by Joe Dirt, Feb 22, 2009.
  1. Joe Dirt
    If anyones curious the master cylinder is a fenco m1945 that you can pick up at most parts stores for around 20 bucks. And has 7/16 and 9/16 ports like the factory disc lines 1" bore, to use my drum lines I had to use a 9/16 to 1/4 adapter, and you have to drill the bolt holes out to 3/8 and shorten the rod 7/16. Work fine with my dual piston pbr's and explorer rears
  2. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    Glad to see someone's getting close, lord knows it's not me.....:Handshake
  3. Joe Dirt
    Went for a longer drive today, got the throttle return spring and alternator spacing fixed, still need to get a air cleaner and get the timing set so I can get this 5500 rev limiter removed that's biult into the msd timing pills
  4. Joe Dirt
    Made the 30 mile jaunt to work this morning
  5. mojo
    Great! How u like the new setup? Congrats on getting it all together...:thumbs2:
  6. Joe Dirt
    Going to do the alignment today, but it already drive and stops way better then the previous stuff, I'm very impressed with the motor as well to be relitivly stock and it pulls pretty good, traction is definately a issue... its as fast or faster then it was before and a ton better to ride in.
    I put a few videos on my youtube channel Rgrimes81 is the username
  7. Joe Dirt
    Decided to use stock 94-95 mustang specs
  8. mavgrab302
    lol....pore thing dosn't know what to be :) Your doing a great job, I looked at the videos sounds very good....
  9. Bryant
    so now that youve got the ls swap done and driving what motor are you puting in next week?
  10. Ryan
    Ryan Ford Addict
    Phoenix Az.
    My money is on a Duramx diesel turbo. :rofl2:
  11. Bryant
    the ford power strokes are now over 1000 ftlbs maybe that will be next. could make for a good lottery to see who can guess joe dirts next motor!!!
  12. Joe Dirt
    Cummins ;)
  13. chirt
    chirt Carlos Hirt
    Massachusetts
    Well, I put my money down that in a few years or less he'll be dropping a new coyote 5.0l :cool:
  14. darren
    Turbine??? LOL.
  15. greasemonkey
    greasemonkey Burnin corn
    Sedalia,MO
    Flux capacitor!
