My very rusty gas tank.pics.
Discussion in 'Technical' started by Thomas, Apr 13, 2009.
  1. Thomas
    Thomas Member
    Vancouver, BC
    73 maverick
    Finished coating the tank.
    After reading other posts I find myself a little confused about getting other parts, sending unit and valve leading to charcoal canister.
  2. 71gold
    "After reading other posts I find myself a little confused about getting other parts, sending unit and valve leading to charcoal canister."
    ...:hmmm:...
  3. 71gold
    what tank is this?
    [​IMG] [​IMG]
    ...Frank...
  4. cometking244
    cometking244 light em up!!!!
    Lubbock Texas
    73, comet 302,allum intake,600 holley
    try a radiator shop they cleaned mine out for almost nothin my wasnt that bad but still bad
  5. Thomas
    Thomas Member
    Vancouver, BC
    73 maverick
    Well, I was hoping for more options on finding a sending unit.
    I read a mustang 68 sending unit would work with little mods.
    Auto krafters 71-73 sending unit would be on back order, and its not really the correct unit for the 73 year. Or, maybe we can get them now.
    My best option would to find a NOS or one in good shape that someone wants to sell me.
    Does anyone have one to sell to me?
    Do I have more options?
    Thanks.
  6. Thomas
    Thomas Member
    Vancouver, BC
    73 maverick
    This is my tank that came out of my 73 Maverick.
    I'm not sure of the fuel capacity 16 gal.? maybe 18 Gal? Do you know?
  7. Grabber5.0
    Grabber5.0 Gear-head wannabe
    Kansas City, MO
    71 Grabber
    That doesn't look like any Maverick gas tank. What part of the tank is that?
  8. Thomas
    Thomas Member
    Vancouver, BC
    73 maverick
    That is the inside top of the tank.The hole where the tubing is, is where fuel goes in. The other hole is for the vent valve.
  9. Craig Selvey
    I have never seen a tank like that one on a Maverick as well. The little vent tube coming off the fill tube is what I question. How is one supposed to remove the fill tube with that vent tube attached to it?
  10. lngroller
    lngroller Member
    Richmond VA
    74 Comet 2dr 250
    My 74 has that as well. The filler tube actually slides into that or at least the top of it.
  11. Craig Selvey
    I am going to have to look at my tanks. Maybe they do have that and I never noticed.
  12. Thomas
    Thomas Member
    Vancouver, BC
    73 maverick
    68 mustang sending unit on my mav
    I went with the 68 mustang sending unit. I drilled a hole in the plate and installed a bolt for a ground wire.
    I hope i have the wires right. I have the yellow wire connected to the original bolt that runs to the green wire on the inside of the tank.
    I connected the black wire to the plate itself with the bolt that i installed.
    Does it look good?:yup:
    I put about 4 gal into the tank, no leaks.
    I don't see the fuel gage working, I guess i'll need to put more gas in it.
  13. FoMoDave
    FoMoDave Maverick Owner
    Cumming Ga.
    1973 Maverick 302 c-4,1971 Maverick 6cyl
    Has anyone replaced the fuel lines on their car? I'm sure no one makes replacements ,but how much trouble would it be to modify ones from a Must. or other model to fit? In the past I have always replaced the lines on my street machines with larger lines for better fuel flow to carbs. Alum. is fairly easy to work with.3/8inch with electric pump works well with most mild engines.I would not trust the fuel lines on those cars after seeing what the tanks looked like!!! If the steel tank is rusted out so is the line!!
  14. Grabber5.0
    Kansas City, MO
    71 Grabber
    Yep, replaced mine with 3/8 aluminum. As you said, it's easy to bend and install, and no rust inside! :D
  15. Dave B
    Right Stuff makes new fuel lines for Mavericks, I have them on my 73.
