Mystery Bulb
Discussion in 'General Maverick/Comet' started by rotorr22, May 8, 2020.
  1. rotorr22
    rotorr22 Member
    Columbiana, Ohio
    During the process of putting my instrument panel back together, I came across this bulb and socket. I cannot figure out what it plugs into. The car is a 1974 Grabber.
    The heater controls have their own built in bulbs and there are no open sockets on the speedo/gas gage pod, so I'm stumped.
  2. Krazy Comet
    Dismal Swamp
    My Comet has a pig tailed lead for alt warning lamp. What color are the wires? Every circuit is color coded.
    As black as that bulb is, it's absorbed a lot of dark... ;)
  3. rotorr22
    rotorr22 Member
    Columbiana, Ohio
    Blue with a red stripe and black.
  4. Krazy Comet
    Dismal Swamp
    Blue with red is a dash lamp, black is the ground. There should be a plug in bulb in the heater controls.
  5. rotorr22
    rotorr22 Member
    Columbiana, Ohio
    My heater controls have their own, built in bulbs. That's where I thought it must plug into as well. Problem is, I can't find a a place on the control to plug it in.
  6. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    My heater control has a hole for a bulb like what you're showing. It's an earlier car though.
  7. rotorr22
    rotorr22 Member
    Columbiana, Ohio
    Anyone have a pic??
  8. rotorr22
    rotorr22 Member
    Columbiana, Ohio
    My heater control has one as well. The mystery bulb I am referring to is in addition to the one in the control.
  9. Craig Selvey
    That is the bulb that goes to the fiber optic wire that goes to illuminate your wiper switch bezel. Should be a socket on the end of that fiber optic that the lamp bulb socket snaps into
  10. rotorr22
    rotorr22 Member
    Columbiana, Ohio
    I think you are correct, Craig. I just don't see the socket behind the plastic fiber tube.
  11. rthomas771
    Here is a pic of the socket and fiber optic tube.
    Craig Selvey likes this.
  12. rotorr22
    rotorr22 Member
    Columbiana, Ohio
    Finally, I get it. My car has been missing this part since I bought it. That wiper washer light never worked and I always assumed the bulb was burned out. I 'll have to pick one up somewhere.
    Thank you.
    rthomas771 likes this.
  13. Maverick Dude
    Maverick Dude Member
    Cranbrook, BC Canada
    I have these two pics from a 73 LDO. In the first pick you can see where the bulb goes for the heater control. It is immediately to the left after you pull out the gage cluster and look in the void, The 2nd pic is the bulb pulled out of the holder.
    82E0C432-C008-4DB6-A9D1-00AA503BBF5C.jpeg B3977C6F-B76B-45FB-AE1B-FED4978EF260.jpeg
