Mythbusting Shelby drop?
Discussion in 'Technical' started by flynbrd, Mar 16, 2011.
  1. stumanchu
    stumanchu Stuart
    Portland, OR
    Micah put '74 reinforcement plates in his car and the bolt holes lined up, so I think it is safe to say that 74 did not incorporate it. I did the drop without a template because I think the templates move the holes forward from where I think they should be. I will admit that I am a novice, and my car is a toy and an experiment, and I have limited car fabing experience, but after moving the holes both down 1 inch in a direction plumb with the bottom of the frame and back 1/16 of an inch, also shiming the front of the control arm shaft 1/8", I have 3 1/2 degrees of caster (according to my calculations) and my wheel is centered in the fender. I cant drive it yet because I have to get Granada tie rod ends for the spindles I put on. o_O I bought moog UCAs, and will have to resort to the ones with the built in drop
    if this turns out to be a failure.
