Name this part
Discussion in 'Technical' started by Ed's 75mav, Feb 28, 2005.
  1. Ed's 75mav
    Ed's 75mav Member
    Phoenix AZ
    1975 Maverick
    how much would you want for it?
  2. Craig Selvey
    It looks like a relay...........but not for the sport lites. I have never seen one plugged in to where you describe.
  3. rayzorsharp
    Nor have I :huh:
  4. MavMark
    MavMark Mega Modifier
    Detroit Area, Michigan
    Yeah, I didn't pay attention to the year...I don't think 73's came with sportlamps...and the relay certainly wasn't mounted in the engine compartment.(I was posting my post at the same time the post about where it was located was being posted...if that makes sense:rolleyes: )
    But that part does look exactly like the sportlamp relay that is in my '72. ;)
  5. 70mav170
    70mav170 Member
    rockwood michigan
    1970 maverick 6 cyl
    ANY PART #'S ON IT? IF THERE IS I CAN TRY AND CROSS IT TO SEE WAHT IT IS, SINCE I WORK IN A PARTS DEPARTMENT AT A FORD DEALER(y)
  6. Ed's 75mav
    Ed's 75mav Member
    Phoenix AZ
    1975 Maverick
    The # on it is D2LB-190592-AB MOTORCRAFT
  7. roush16
    roush16 Member
    waynesboro pa,
    76 2 dr mav..712drmav..74grabber
    its the thing that starts the warp drive
  8. 77mav302
    77mav302 Member
    Spokane WA.
    77mav302/2dr, 70mav 2dr
    what-his-name called and said that thingamajig you showed him caused his whatchamacallit to heat up!
  9. Mavaholic
    I pulled my relay out of its hiding place and it dosent look like the one you have. Does the car run without that part installed? Does the plug and wires look factory? If it does I'm guessing that yours might be part of the seat belt interlock system. If you have a meter it might help you figure out whats going on. 2 of the terminals will be the relay coil and the other 2 are the switch. The coil should measure some resistance, somewhere around 40 ohms. when you figure out which 2 terminals are the coil, jump 12 volts to them. you will hear the relay click. Then see if it heats up. If so, then the coils is going bad. If not, than the circuit it's switching is got a problem in it. You might try Charlie Pings websight to get some wiring diagrams. Here is a picture of the sport lamp relay.
  10. Craig Selvey
    1975 shouldn't have the starter interupt system....only a 1974 thing. I have one on the 74 LDO and I didn't see no relay like that.
  11. SuperByelich
    SuperByelich Jesus Is Lord.
    Chincoteague, Virginia
    1971 Maverick Grabber
    Great Scott! Marty!? The Flux capacitor? We must get it back.. we must go back... to the future!
  12. 70mav170
    70mav170 Member
    rockwood michigan
    1970 maverick 6 cyl
    Well Part Does Cross Over To A D2ly.19d592.a Whick Is Updated To A 1u2z.19d592.aa Or Motorcraft Part# Yh1601 Parts Is Still Available List Is 50.24 I'm Sure I Could Get It For You. It Is Called An Automatic Tempature Control Relay. Catalog Only List It For A 74-77 With A 250 6 Cylinder As For What Its Is Used For Give Me Some Options Of Your Mav, Does It Have A/c, Rear Defroster? I Have Been In The Business Since 86' But The Boss Has Been In It Since Henry Ford Was Here..:d Hope I Can Help I Sure I Can Get You A Wholesale Discount On The Part
  13. Mavaholic
    Well, I found a wiring diagram for a 75 off of a link from Charlie's websight, and it shows a red wire with a light blue chaser going to a seat belt over ride relay. Only problem is I couldnt find any other mention of this relay in the diagram, so who knows. I guess your going to have to do some wire chasing to figure this one out. Too bad you dont live around here, I like solving problems like this.
  14. Ed's 75mav
    Ed's 75mav Member
    Phoenix AZ
    1975 Maverick
    Mavaholic I which I lived closer also, or that I had the money to fly you down here to AZ:162: Since we are having problems with the ignition module blowing on us The car is a 75 mav but the engine(200) is out of a 81 T-brd w/ Ca. emissions or atleast that is what we were told by a parts store.
  15. Ed's 75mav
    Ed's 75mav Member
    Phoenix AZ
    1975 Maverick
    70Mav, It does have a/c, no rear defrost and of course a heater
