Need a fuel guage
Discussion in 'Technical' started by sabrina, Feb 11, 2008.
  1. Rando76
    Rando76 Member
    Claremore, OK
    If he actually checked the sender, then he drained the tank and removed it. I don't know how he could check the sender without doing that. I just don't want you to end up going around in circles over something simple - like a sender. :(
  2. sabrina
    sabrina EyeNurse
    Roanoke, VA
    1975 Maverick "Frankie"
    Hey, Randy--I was just noticing all the cars that you have. All you are missing is a 75! Man! That's a LOT of cars! :bowdown:
  3. Jamie Miles
    Alto, GA
    I've had a few
    To check the gauge and assorted wiring going up to it, do like Craig says. If you look under the left side rear of your car at the gas tank, you will see where the fuel line goes into the gas tank. You will also see a wire with a plug on the end of it. Pull that loose, and use a paper clip or another piece of wire or something to short the two terminals together (this is all very low voltage, so no worry of getting shocked or anything). Turn the key to the ON position. The fuel gauge should sweep all the way to full.
    If it goes to full, it's the sending unit causing the problem. If not, you will need to pull the cluster out of the dash. The way to test the fuel gauge itself is to take a 9 volt battery and connect it between the two terminals on the back side of the gauge (there will be nuts on these terminals also). If the gauge starts sweeping to full, you know it's good, disconnect the battery immediately. Do not let it go all the way to full and just hold it there with the battery connected, as you may damage the gauge. I guess I'm the only one here who has had the gauge itself go bad. I've replaced two of them.
  4. sabrina
    sabrina EyeNurse
    Roanoke, VA
    Jamie--thanks. Sounds easy enough. Steve and I ought to be able to muddle our way through that. Thanks.
  5. Rando76
    Rando76 Member
    Claremore, OK
    If you find a '75 - let me know. HAHAHA :rofl2::rofl: :bouncy:
  6. Craig Selvey
    That should be easy enough to do....considering the MCCI Roundup Nationals will be in YOUR state this July. See you there....I am bringing my tool box....and my appetite. :D
  7. sabrina
    sabrina EyeNurse
    Roanoke, VA
    WHAT???? Wait, wait. VIRGINIA?? When? I guess I am probably supposed to know this already.
    Where is that information??? (I am sure that is a stupid question--so please don't blast me :cry:)
    Seriously....where do I find info about MCCI Roundup Nationals in VIRGINIA?
    Wait-- :idea: I guess I would know that if we were supporting members, huh?
    Uhhhh--maybe it is time to stop procrastinating about that???? :oops:
    What kinda cookies (or whatever) do you like???? :D
  8. 71gold
    "What kinda cookies (or whatever) do you like???)
    ...are..pancakes...cookies :huh:
    ...:D...
  9. sabrina
    sabrina EyeNurse
    Roanoke, VA
    Uhhhhhhh. Well. I would need a portable griddle. :cry:
    Don't know if I could work that out. I guess it would have to be something I could cook at home and BRING with me. :yup: Sorry. But you know what? I could drive us to IHOP! :drive:
  10. sabrina
    sabrina EyeNurse
    Roanoke, VA
    OK--I did it. I mailed in our membership application and dues. Now are we "REAL"? :p ;)
  11. 71gold
    ...they ship ...pancakes...around the world every day ...:huh:you should have no prob. taking some (6-8) a few miles down the road. (y)
    ...:yup:...
  12. sabrina
    sabrina EyeNurse
    Roanoke, VA
    OK FINE! YOu forced it out of me........I COOK HORRIBLE PANCAKES! Try me on something else. For the Pancakes, talk to Aunt Jemima! :)
  13. 71gold
    ...:cry: :cry:...
  14. Craig Selvey
    Real simple....on the Maverick Comet Club International website:
    www.maverickcometclub.org
    Lots of info there about the Roundup Nationals...as well as how to join!!
  15. Craig Selvey
    Congrats....you won't regret it!! :D
    P.S. I like Chocolate Chip.
