Need a little help
Discussion in 'Technical' started by Rome0806, Jun 15, 2006.
  1. 71gold
    back to the question...i choose answer #3...:yup:
    ...frank...:bouncy:
  2. Rome0806
    Rome0806 Member
    OH
    1977 Maverick
    got rid of it
    I got rid of that motor and I am just going to keep the stock 250.
  3. baddad457
    If you're going to do an "M" swap, might as well go for a 460. They're about the same width. But the 460 has twice the power.
  4. baddad457
    Agree with all but the "weak bottom end" and "don't turn a 400 over 4500". You've never looked at the rods and crank in either to say this. The rods are as strong as the 429CJ and 460 truck rods. Ditto for the crank. I built a hotrod 400 and it was turned regularly to 6500 and it never came apart.(y) Downside to it was it's affinity for 93 octane fuel with the pistons used (351C forgings with the pin bores opened for the 400 rods)and open chambered heads.
  5. eagles5108
    eagles5108 New Member
    new hampshire
    would like a comet with a 302
    ive never seen a engine stand using the bellhousing, usally u just bolt it up to where the bell bolts go
  6. tim keck
    sharps chapel,Tn
    Don't have to look at 'em.There are 2 kinds of 351m/400s around here.Those that are rod knocking/mains rattling and ones that have been rebuilt "with a new crank kit":16suspect.Very few have I seen with 100,000 plus miles that weren't in need of a crank.I'm glad Tim Meyer is doing something for these engines,but stock for stock,I'll take a worn out 460 any day.JMO
