Need a smaller Master Cylinder
Discussion in 'Technical' started by olerodder, Mar 24, 2010.
  1. 71gold
    ...and where might you find these?
    ...:Handshake...
  2. facelessnumber
    facelessnumber Drew Pittman
    Memphis, TN
    '71 Grabber
    Found mine by rummaging in the back of the local Auto Zone. The two flare nuts you'll need that fit this master cylinder and the Maverick's 3/16" tube size are:
    AGS part # BLF-48C-5 - M12x1.0
    (interchange Edelmann part # 276012)
    and
    AGS part # BLF-39C-5 - M10x1.0
    (interchange Edelmann part # 276110)
    And you'll be doing a "bubble flare."
  3. mojo
    Bubble Flare
    Clue me in. What is a Bubble Flare. When I do this mod I want to make sure I get it correct. Can't screw around w/ brakes.
    Thanks
  4. facelessnumber
    Memphis, TN
    '71 Grabber
  5. 71gold
    this is good info. :Handshake
    maybe move it to...Tech Articles
    ...:yup:...
  6. mojo
    Facelessnumber:
    Thanks for the info. I never heard of that kind of flare. I was only familiar w/ the double flare. Im sure a lot of others have'nt either. Anyway, appreciate ur Cluing me/us IN.
  7. olerodder
    olerodder Member
    NorCal
    I will second the thanks, and look forward to performing this swap soon. I will try and take some pictures so it can be used for the next person.
    Thanks again,
    John
  8. 71gold
    i have used them on metric fittings...:yup:
    ...8" rear disc. install
  9. facelessnumber
    Memphis, TN
    '71 Grabber
    Indeed. Your Explorer rear disc article is the reason I learned how to do a bubble flare.
