Need Diesel Advice! Please....
Discussion in 'Other Automotive Tech & Talk' started by Country Mav, Aug 11, 2007.
  1. RobertBailey
    RobertBailey MCCI & MCG Member
    Lenoir City, Tennessee
    1972 Grabber Clone,1970 Maverick, 1973 Grabber, 1973 2dr, 1973 Maverick(Parts Car) 2000 Ford SD Truck PowerStroke
    forgot ...mine caught fire 2 winters ago....had the block heater plugged in and it shorted out. Caught it all on my video security system.
    Robert
  2. Country Mav
    Evans, Louisiana
    72 2-door Maverick 308/C-4
    Thanks for all of the replies and advice! I really, really appreciate it! I'm planning to head out to look at the truck Tuesday and I have all ideas that I'll be driving it back home. This is exactly the truck that I've been wanting. Again, thanks so much!! Y'all take care! Preston
  3. Country Mav
    Evans, Louisiana
    Actually, if I get it....I'm gonna have a trampoline mounted on each side....That way it'll be "unique":thumbs2: :D
    And are you trying to say I'm short? :hmmm: I can't help it if you're jealous of me because I'm the perfect height......:huh: :bs: :biglaugh:
    :D
  4. Hawkco
    Hawkco Genuine Car Nut
    Rex, Georgia (GA)
    77 Maverick
    Nothing wrong with short. I can do everything a tall person can; I just have to use a stool or ladder. I don't have to duck for door jams, ceiling fans, and I can go through the kid's door at the Chick-Fil-A with a slight bend.
  5. Blown 5.0
    MS.
    1974 Maverick
    Keep a check on the DCA content, Ive saw more of the 7.3,s go down because of this than any other problem.
  6. Country Mav
    Evans, Louisiana
    DCA content? What's that?
    I feel ya Mr. Terry! I can't even jump and hit my head on much!! :D
  7. fastfords
    fastfords Member
    East Tennessee
    70 Maverick, 71 Comet GT, 72 Sprint, 75 Comet, Maverick Stallion
    I have a 2000 Crew cab 4X4 with 325,000 miles on it, it runs great and does not have any leaks. I use it for every thing, hauling, pulling, off road (only on solid ground due to the weight), traveling, and it does pretty good against the chevy and dodge boys. I ordered it late 2000 andpicked it up early 2001 and it is titled as a 2000. The only things that I have done to it are: the cold air system, guages, and a Edge programer.
    I had to rebuild the automatic tranny around 200,000 miles ($2,200.00) I have changed the water pump three times (thats a b%@#h), had the turbo rebuilt (the bolts started backing out and Ford sells a repair kit), two sets of lock outs, and about five sets of rotors. other then that cam positon sensers.
    I change oil every 5,000 miles and fuel filter every 20,000 miles. If the truck looks good, runs good, and was well maintained I say GO FOR IT.
    Good luck.
  8. Country Mav
    Evans, Louisiana
    Thanks so much y'all!! I'm gonna call the man tomorrow and set it up to go out there! Definitely gonna take money. I very seldom spend any money on myself and I think that this is something I will really enjoy for a long time! I hope.... :D Y'all take care!! Preston
  9. ford84stepside
    ford84stepside Lone Wolf
    Berry Alabama
    1947 Lincoln Zephyr Coupe
    Preston, go to any good truck parts store and they will sell you a DCA test kit. It measures the level of , dang can't think of the name right now, in the coolant. In a diesel, and some aluminum engines you have to use supplemental cooling additives to keep the DCA levels low. It prevents electrolisis from eroding the sleeves or cylinder walls. Too much is as bad as not enough, the levels need to be kept at a constant. The kit will have a bunch of test strips that you dip into the coolant and compare the color to the chart on the bottle. You check it every time you change the oil, most times it will not need to be changed as a bottle of SCA will last a long time.
  10. Country Mav
    Evans, Louisiana
    Thanks!! I've never heard of that!! Thank you VERY much! Learned something new tonight for sure! That will definitely be something to keep in mind for future reference....
  11. ford84stepside
    Berry Alabama
    Nitrates is what I couldn't think of last night.
  12. RobertBailey
    well I just got finished replacing the right hub assembly $500.....the ABS came on a couple of days before heading to the gathering and on the way back I heard a roar for a bit from the front then it went away......well 600 miles there and back then 600 more to alabama to get maverick#8 the bearings went out today coming home from work....I made it home and the hub was hotter than he-- . took it all apard and had to use a slide hammer to get it off....had a nice tick and clunck when rotated. So some time in the next day or two I will take the drivers side off and check it......got 117,000 on it
    figure it is time for some things to start wareing out.
    Robert
