Need help guys. T-5 into 70 model
Discussion in 'Technical' started by maverickdragger, Nov 28, 2011.
  1. maverickdragger
    maverickdragger GearHead
    Oneonta, AL
    1973 Maverick
    Yeah. The motir and clutch came out of a running 90 model. The trans from a 89. Ive been so frustrated i know im overthinking things. Anyone got pics as i clear my brain with tequila!!!
  2. 71gold
    correct...the intake has a 4 degree pitch down for motor pinion angle when intake is level...front to back...
  3. bmcdaniel
    Your clutch disc must not be aligned. Helps, too, to use threaded dowels (7/16 bolts with the heads cut off) in the two upper block / bellhousing holes to make sure the bell and tranny are going on straight.
    The distance between the T5's output shaft and mounting pad are the same as other Ford small block trannys so using the stock crossmember as a guide will give you the correct angle.
  4. igoback70
    igoback70 Member
    IN
    70 Maverick
    Hold up wait a minute. UNBOLT THE TRANS FROM THE BELLHOUSING !
    Install the clutch - pressure plate and bellhousing first. Dont forget the clutch fork.
    THEN install the T-5
  5. 71gold
    are the..pilot shafts the same length? '89 to '90
  6. bmcdaniel
    You must not have asked, I did mine in '96. LOL
  7. igoback70
    igoback70 Member
    IN
    70 Maverick
    Do that part first dragger, it makes the install MUCH easier.
  8. StrokedGrabber
    StrokedGrabber Member
    Quartz Hill, CA
    1973 Grabber Maverick
    easiest way ;) thats how i use to change my trans out in my fox body when we blew them up every month...i always left the bell housing on the motor and just took the trans out...got so good that i could change them out on my back on the ground in about 45 mins start to finish :)
  9. maverickdragger
    Oneonta, AL
    1973 Maverick
    I will do that. Im so ready to be driving this one
  10. igoback70
    igoback70 Member
    IN
    70 Maverick
    I'll swap with ya, you sand mine for me and i'll install that trans for ya. :Handshake
  11. maverickdragger
    Oneonta, AL
    1973 Maverick
    Hey i am a painter. I have the efi wiring done the motor stands built. All i like is boltin the trans in.
  12. igoback70
    igoback70 Member
    IN
    70 Maverick
    What are you doing as far as pedels ?
  13. maverickdragger
    Oneonta, AL
    1973 Maverick
    I modded a mustang pedal
  14. igoback70
    igoback70 Member
    IN
    70 Maverick
    We would be on the same page there, i combined, clutch pedel and quadrant from a stang/ brake pedel Mav. I had to notch a bit off of the wiper motor mount so the quadrant had the clearence it needed, but the set up has worked perfect for over 10 years, i was very hard on it the last time it was on the road.
  15. 302-72-mav
    302-72-mav Member
    sactown CA
    and some pic's
    pic's of it all in my 72 mav
    my hydrolic setup but had to go to the cnc master & slave
    stock driveline installed i had a inch takin out of it after driveing for a few weeks
    now it all going in my -- 3 on the tree 69.5 mav
    had to trim the tunel a lil fot the T5
    3-core aluminum rad and tauris fan
