need help with power steering
Discussion in 'Parts Interchange' started by carcrazy1964, Aug 2, 2022.
  1. carcrazy1964
    carcrazy1964 Member
    1976 ford maverick
    i have a 76 ford maverick that had the 250 inline in it i jut dropped in a 1968 302 ive been told i cant use my current power steering pump from the 250 is this true? im also having an issue finding the correct brackets to mount it anyway ...what are you guy using for brackets and steering pump? i dont want to delete the power steering as some recommended..any help woud be appreciated
  2. Krazy Comet
    Which side of vehicle is the water pump inlet located? A '68 will have passenger side lower hose, while '70-newer has it on driver side. Different brackets are required. As far as P/S pump, all bolt up same, pulleys & hose connections differ. I doubt 6 vs 8 hoses will interchange.
    For reference here's the '67-'69 setup, bracket on pump is aluminum(I don't think I'd trust that pump). These brackets also fit big block so are usually expensive. Bracket for '70 up is steel, they do not interchange. Adapter brackets that bolt pump bracket to water pump are different as well.
    https://www.ebay.com/itm/134150913512?hash=item1f3c047de8:g:Ha0AAOSwuM5ir5x1
  3. old55guy
    old55guy Member Supporting Member
    Flat sac , Ca.
    Can I have your pulley off of your P S pump ??? Or even a picture of pulley , I need one for my 250 Maverick ???
  4. Krazy Comet
    Here's the exact pulley from a '77 Maverick 250.
    Note offset toward front of car, it's currently on my 428CJ.
      File size:
      183 KB
      12
  5. old55guy
    Flat sac , Ca.
    thank you thats the pulley that i have now ,i need a pulley that has a offset toward pump ? I am off by about 1 1/2inches ,I am not sure so many different pulleys are for sale ??? thanks for quick reply
    428 Cj jeep , ? do not break it
  6. Krazy Comet
    Jeep? Blasphemy, 428CJ = Cobra Jet
    Here the factory pulleys on my '72 Comet(top) Lower on my Fairlane cometengine 006.JPG FairlanePS1020 003.JPG
    old55guy likes this.
