NEED HELP
Discussion in 'Parts Interchange' started by Themechanic666, Jul 13, 2021.
  1. Themechanic666
    Themechanic666 Member
    Waco Tx
    76 maverick & 75 comet
    I have a 1975 mav that originally had a 250 i6 and recently I started doing an engine swap with a 1968 302 block. I have all the required parts to make it work but I’m stuck right now trying to figure out if my water pump is reverse flow and if that’s going to impact on my engines cooling capabilities, or if I need to use a different application to make this engine run happy . And quite frankly I am confused as hell .
  2. Krazy Comet
    Reverse flow are serpentine belt applications that operate pump from back side of belt, didn't exist till mid '80s.
    V belts are all std rotation.
    Pulley bolt pattern is wider on reverse rotation serpentine, std rotation pulley will not bolt up.
    I'm yet to see a '80s T-Bird/Mustang with reverse rotation pump, that did not have a std rotation timing cover.
  3. BBMS18
    BBMS18 Member
    Grand Rapids, Michigan
    75 Comet
    There are differences is timing covers for standard & reverse rotation.
    mojo likes this.
  4. Acornridgeman
    Wisconsin
    It is not that it is reverse flow - the radiator hose is either drivers or passengers side intake. So the early 302 pump intake (68-69) was on the passenger side.
    Krazy Comet likes this.
