Need new rims and tires
Discussion in 'Wheels and Tires' started by Rev Ron, Jan 4, 2021.
  1. Rev Ron
    Rev Ron Member
    Dalzell, SC
    Comet GT
    Wow, I have read across this site about all the rim and tire sizes that you have put on your Mavericks and Comets. There doesn't seem to be much of a consensus on what is best, so let me get your input from your experience. I have a 71 Comet GT. It is stock suspension with front disc brakes and rear drums. I am currently running 15" Magnum 500's, 7" rims. I have the BF Goodrich Radial T/A's and want to stay with those tires. I am fine with the front rims and tires, but that size looks pretty wimpy on the rear and want to buy new Magnum 500 rims and T/A tires. Yet, I don't want to look redneck or have any rubs. I sure don't want to have to mess with the stock fender well. You can see the picture of my Comet and it is perfect, so I won't or adjust any sheet metal. I have standard gas shocks on the rear, but may go with a lite air shock to lift the rear just a few inches. I am debating whether I go with a 15" X 8" or 15" X 10". Will I have enough clearance? Or, do I look at a 17" wheel? Then again, I don't want that 'jacked up' look on the car. I appreciate the factory look but am willing to flex just a little. I appreciate what you may think, but need to hear from you who've got actual experience on this. I don't want to buy new rims and tires, then have them rubbing or bumping. Thanks.
  2. Rev Ron
    Rev Ron Member
    Dalzell, SC
    Comet GT
  3. Acornridgeman
    Wisconsin
    Ron, what tire size do you have in the back? You can probably use the rim you have now and put a bigger tire on it to fill out the wheel well.
    Maverocket likes this.
  4. Rev Ron
    Rev Ron Member
    Dalzell, SC
    Comet GT
    All four rims are the 15x7 rims with 225/60-15's on them. I am told that is the maximum sized tire I want to put on a 7" rim. That is why I was thinking of an 8" rim. I can then put a 255 or 245 on them.
  5. Acornridgeman
    Wisconsin
  6. Rev Ron
    Rev Ron Member
    Dalzell, SC
    Comet GT
    Thanks. I've never seen that chart. I wonder what would be better with the 7" rim... 245/60-15 or the 235/70-15? Isn't the 235/70-15 a touch taller but not as wide?
  7. Acornridgeman
    Wisconsin
    Exactly
    Compared to what you are running now the 235/70 will be about 2 1/2" taller and 1/2" wider --- the 245/60 would be about 1" both taller and wider
    Either have an ideal rim width at 7"
  8. BBMS18
    BBMS18 Member
    Grand Rapids, Michigan
    75 Comet
    Just for reference this is a 255/60-15 on a 15x8 wheel.
    Car is on the ground, jack is just under the car while I was test fitting.
    7708AF67-6823-44DC-BCBF-DE1192304DB9.jpeg 968A1376-077B-42F1-9F5E-164072CDC95D.jpeg
    I believe this is a 225/70-14, he changes tires more than most people change their socks.
  9. Rev Ron
    Rev Ron Member
    Dalzell, SC
    Comet GT
    I know beauty is in the eye of the beholder... but I like the larger tire a very much. Is there any problem with it rubbing?
  10. Acornridgeman
    Wisconsin
    I also run a P255/60/15 on the rear of my 72.
    15x8 wheel
    I did roll my inner fender lips to clear but this was due to having a wider 9" rear end in this car. If you have a stock rear it should not need rolling.
  11. BBMS18
    BBMS18 Member
    75 Comet
    It will depend on the condition of the springs on your car.
    The same wheel & tire actually fit better on my car. 97899268-A63A-4662-8840-EA366E77CFD1.jpeg
  12. Rev Ron
    Rev Ron Member
    Dalzell, SC
    Comet GT
    From the pictures I see, I am leaning toward buying a new set of 15x8 rear rims and 255/60-15 Radial T/A's. However, I have not thought about the condition of my springs. How do I know that I have good springs? I will research this site, but all input is greatly appreciated on both rims/tires and on springs. Thanks.
    Russell likes this.
  13. Craig Selvey
    Ron.....do NOT put air shocks on that gorgeous car!! Air shocks can and will rip (yes I said RIP) a hole into the sheet metal of your car. The upper shock area of a Maverick was never designed to hold the weight of the car, and that is exactly what air shocks do...they hold up the weight of the car.
    Slightly wider wheel....or at least a wider tire....is your best bet.
    If you want a slight lift, new rear leaf springs will do that.
    mojo, Shorty and jasonwthompson like this.
  14. Rev Ron
    Rev Ron Member
    Dalzell, SC
    Comet GT
    Thanks, Craig. I do not see myself doing that, either. I guess I was talking with my mouth open and mind not in gear. I remember by brand new Comet GT (Bearcat) in Feb 1972. As all of us did back then, we put on Hijacker air shocks and ran super wide ties. I also remember having issues, especially when the weld on the top rear shock mount started to crack. You're super right, not on this one! I think I will stick with the 15x7 rims and put some 235/70-15's on. They will be a little taller and wider. I don't see the cost of the 15x8's and size difference all that much. Thanks!
    Craig Selvey likes this.
  15. BBMS18
    BBMS18 Member
    75 Comet
