Need some advice on wheels/tires
Discussion in 'Wheels and Tires' started by Stephen1822, Sep 10, 2019.
  1. Stephen1822
    Stephen1822 Member
    New York
    ‘77 Maverick
    Hey guys, here are some photos of the 77 Mav I bought. I want to get wider wheels. Nothing like drag wheels, but something that is meatier and fills the space better ( I do love the white stripe though!). Any ideas?
    BBMS18 likes this.
  2. stumanchu
    stumanchu Stuart
    Portland, OR
    There are seemingly endless choices in style, size, and backspacing. 14" wheels are getting more difficult/expensive to find sporty tires for. The backspacing built into the rim is critical to get in the proper range so nothing rubs on the body or the suspension. As far as what you would like to see on your car.....look at wheels on peoples cars and decide what you like. Do a lot of research, and figure out how much you want to spend. check out the "garage" in this forum, as some people list tire and wheel information as part of their garage. My rims are 14x7 with 3.5" backspacing (I wanted this style and didnt realize the challenge to get 14" tires). Also, make sure the bolt pattern is correct. Many people use 15" rims and larger to get more tire choices.
    Stephen1822 likes this.
  3. Maverick_Ian90
    Maverick_Ian90 Member
    Northeast
    1975 Ford Maverick Grabber
  4. BBMS18
    BBMS18 Member
    Grand Rapids, Michigan
    75 Comet
    This is the information I collected of what people are running on theirs.
    Maverick/Comet wheel/tire combo’s
    FRONT
    14x7 w/ 225/60-14s
    15x5 w/ 195/65-15s
    15x7 w/ 225/60-15s
    16x7 w/ 245/45-16s
    3-1/2 or 4 inch backspacing
    Front 17x7 w/ 245-40/17s
    4 inch backspacing.
    REAR
    14x8 w/ 235/60-14s
    15x8 w/ 245/60-15s
    15x8 w/ 255/60-15s or G-60/15s
    15x8 w/ J-60/15s (M&H racemasters)
    16x8 w/ 255/50-16
    18x8 w/ 275/35-18
    4 inch backspacing
  5. Stephen1822
    Stephen1822 Member
    New York
    ‘77 Maverick
    This all helps. Thanks a lot guys!
    BBMS18 and Maverick_Ian90 like this.
  6. x72COMETx
    x72COMETx Member
    Vallejo CA
    Old picture, fronts 15x7 3.75” backspace tires are 215/60/15, rears 15x8 4.00” backspace tires 265/50/15. The rears would fill out an unrolled/pulled quarter pretty well
    Stephen1822 and BBMS18 like this.
  7. canuck222
    canuck222 vroom, vroom... Supporting Member
    Woodstock, ON
    '73 Mercury Comet, 302, Auto
    These posts are helpful, I just wished the tracking was more complete, or maybe confirmation that there was a safe size combo for each rim size front and back, like how do I know if 15x7 w/ 225/60-15s, 4" BS works for all four wheels? I found many posts of how big can I go instead of what is a size that will likely work...
  8. jasonwthompson
    jasonwthompson Member
    Carrollton TX
    For awhile I had factory Magnum 500's all way around. They were 15x7 4.25" bs with 225/60-15. Never had an issue. Now the fronts are 15 x 7 4"bs with 235/60-15. The backs are slightly larger diameter with 255/60-15. I would think that 15x7 w/ 225/60-15s, 4" BS all way around should give you no problems.
    canuck222 likes this.
  9. canuck222
    Woodstock, ON
    So not to hijack this thread but I know there is some annoyance over so many threads asking essentially the same question...
    I have a lead on a set of four 15" x 7" American Racing rims (centerline / outlaw style) in 5 x 4.5" bolt center, ET -6 (4" back spacing) with Goodyear Assurance 215/65R15 mounted. I don't think there's any issues with the backspacing from all the post searches I've performed but the I have had little luck with regards to the aspect ratio of 65R - is this getting too tall? (everyone on here seems to prefer 60R) The purchase only makes sense if the tires can be used.
  10. BBMS18
    BBMS18 Member
    75 Comet
    https://www.tacomaworld.com/tirecalc
    Put in the info of the tires you have on the car and the info of the tires your looking at and go from there.
  11. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    The 215 65 would probably be a good height. That was the size tire out 92 Camaro RS had and they weren't a tall tire, probably comparable to a 235 60.
    Edit....used the calculator above and the 215 is the same height as a 235 60.
