Need some help, just swapped torque converters...
Discussion in 'Technical' started by adam 72, Jan 24, 2012.
  1. adam 72
    adam 72 Member
    New Mexico
    1972 maverick
    when I push the drivers side tire forward the drive shaft spins and my passenger tire goes in reverse. The eventually forward. Does that mean anything
  2. Ryan
    Ryan Ford Addict
    Phoenix Az.
    Ive never tried this but I think you may want to do it to see if the pump is working. You can remove one of the trans. cooler lines from the radiator and put a rubber hose on it and lead it to a catch pan. Start the car and see if you get fluid pumping out of it. If the convertor is seated correctly into the pump and the pump is good, and you have line pressure then it should pour fluid out into the pan.
  3. adam 72
    adam 72 Member
    New Mexico
    1972 maverick
    And it sounds like leaves crumbling as it turns. Every so many rotations
  4. yellow75
    Tillamook Oregon
    You would want to unhook the front line on the transmission, it is the pressure side the rear one is the return.
  5. ShadowMaster
    ShadowMaster The Bad Guy
    The ShadowLands
    1969 1/2 Maverick
    Anybody else see a problem here?
  6. adam 72
    adam 72 Member
    New Mexico
    1972 maverick
    I've checked the dip stick up and down. Not only up. I just unhooked the cooling lline and its on dripping wwhen on
  7. ShadowMaster
    The ShadowLands
    1969 1/2 Maverick
    Then you're not engaging the pump.
  8. Ol Maverick Man
    Ol Maverick Man Member
    Wallingford, Ct.
    1973 Maverick Grabber Clone
    Check the fluid level on both sides of the dipstick. I've had times when one side of the dipstick is reading high and the other is reading low. One side can pick up oil off the dipstick tube.
  9. adam 72
    adam 72 Member
    New Mexico
    1972 maverick
    Well I'm sure it was seated correctly when we put everything together. I'm about to check the dip stick again
  10. 71gold
    how many quarts have you put in so far?
  11. adam 72
    adam 72 Member
    New Mexico
    1972 maverick
    At the most 5. Least 4
  12. Bryant
    put 4 more in then see what happens
  13. adam 72
    adam 72 Member
    New Mexico
    1972 maverick
    Its starts to over flow. That's why I haven't
  14. Bryant
    of every thing you have said, the amount of atf is the consistent problem. when i put a new trans and converter in i will put 4 quarts of fluid in then start the car then put the rest of the specified capacity in. the trans needs to be running to be able to pump the fluid into the converter which holds most of the atf. also the trans needs to be close to level to get an accurate reading on the dip stick. sense you have started and have the motor running the 4 quarts you have put into the trans should have been pumped out of the pan and into the converter. if you still cant put any more fluid in then you have defiantly not engaged the pump when you put your converter in. it is possible that you have damaged the pump and even damaged the transmission from running it with out the pump working.
  15. adam 72
    adam 72 Member
    New Mexico
    1972 maverick
    That's what I wasn't hoping for.vthanks guys..
