Need to Replace my Front Seatbelts, but can't find parts
Discussion in 'Technical' started by Red 5, May 26, 2020.
  1. Red 5
    Red 5 Member
    1977 Mercury Comet 4.1L Inline six
    I've got a 77 Comet with driver and front passenger bucket seats. recently I've noticed that the driver's side belt is starting to wear at the high anchor point of the shoulder harness. In addition both belts look old, and the hardware is starting to look worn. No biggie, I figured, I'd just pop online and order a new set of belts and hardware. I was wrong. I've been looking for two days on line and I can't find anything that says it will fit a 77, 76, 75, or 74 Maverick or Comet, plenty of Cougar belts, loads of mustang belts, and other belts but no Comet or Maverick belts. Not one site says they have the parts. So here's my question, does anybody know of a OEM supplier for both the belt and the hardware, and if not, what is the best option. I'm looking for functionality, and little to no additional work, though I do plan to replace the carpet at the same time I do the seatbelts. Also, as a temporary measure can the passenger side belt be used on the driver's side until parts arrive, or should I just plan on parking the car until I get the parts?
    Thanks!
  2. BKelley
    BKelley Comet Enthusiast
    Stone Mountain, Ga
    "72" Comet GT
    CA189HJN and Red 5 like this.
  3. Maverick Dude
    Maverick Dude Member
    Cranbrook, BC Canada
    Type “seatbelt” in the search function. There is a wealth of information available.
  4. Red 5
    Red 5 Member
    Thanks Kelley, Just sent them an email and am waiting to hear back.
  5. leeinphx
    leeinphx Member
    Show Low Arizona
    1975 LDO
    I had them reweb the front belts for my '75, they did a good job
  6. CA189HJN
    CA189HJN Robert Couse-Baker
    Sacramento, California
    1973 Ford Maverick 4-door 302
    I used them for my Miata and the belts came back better than new. Really awesome service.
    On my Maverick, I used generic retractable belts intended for use in the back seats of vans (My '73 was the last year they put the top mounting point way behind the driver, with a detachable, non-retracting shoulder harness).
    You should be able to get a good-quality generic that will bolt in. However, if you use a generic belt (as opposed to having seatbeltplanet do their thing), you will lose function of the "fasten seat belt" light, which is unlikely a dealbreaker for anyone.
    Red 5 likes this.
  7. Hotrock
    Munroe Falls, Ohio
    Red 5, mojo and mvw66gt like this.
  8. Red 5
    Red 5 Member
    Thanks Hotrock for the idea.
    I do have a couple questions. In my car the retractors were recessed into the rocker panels from the cabin side, and covered with a trim peace, I see you have the belts bolted directly on, did you have to modify the rim panels at all to get the arrangement to work, and would you foresee any problems in a car with adjustable seats? Could you post a picture of where the seatbelts are anchored inside? And second, how did you lower the attachment point on the roof so the belt wasn't too high on your chest? On my car there's, as part of the entire seatbelt assembly an extender attached to the upper attachment point on the ceiling.
    P.S. your idea is looking really appealing right now especially against the higher cost for re webbing the belts, and with the added plus of new newer but classic looking hardware.
  9. dyent
    dyent Member
    vancouver bc
    Starting in 74, our Mav/Comets had their seatbelt assemble recessed into the rocker panel, having them re webbed by SeatBeltPlanet will allow to you reinstall back into their OEM locations, no modifications required or hassles, plus they will be DOT certified.
    David
    Red 5 likes this.
  10. Red 5
    Red 5 Member
    Thanks David! I was wondering about that.
    Also, I plan to contact Seatbelt planet tomorrow morning to get more details about re webbing, but since you're here do you know the rough turn around time?
  11. dyent
    dyent Member
    vancouver bc
    With this Covid19 going around, best give them a call and they will have a good idea how long it will take. It has been a few years since I purchased new retractable seat belts for my 73 Comet, Steve was the person I talked to. They can throughly check/rebuild (if necessary) your seat belt assemblies back to new condition and will have DOT certified label stitched to the webbing.
    www.seatbeltplanet.com
    (405) 736-0088
    David
    Red 5 likes this.
  12. Hotrock
    Munroe Falls, Ohio
    Red 5,
    dyent may have answered your questions. I'm not familiar with the details of the newer model Mavericks and Comets. I have included some photos of my install as requested.
  13. Red 5
    Red 5 Member
    Thanks Hotrock,
    looks like my car is a little different with an additional trim peace over the retractors, and like the re webbing might be my best bet. Thanks though!
    Here's a photo of where the retractors are mounted (the two back rectangles are the gasket around where they are recessed) and of the retractors them selves out of the car. Retractor recess.JPG
  14. dyent
    dyent Member
    vancouver bc
    Just send both retracters as is to Seat belt planet once you have contacted them, they will do their thing and when you get them back, just a matter of popping them back in place, piece of cake!
    David
    Red 5 likes this.
  15. maverickita
    maverickita New Member
    WA
    1975 Ford Maverick 2-door 250cid inline 6
    Hello! I'm struggling to get my front bench belts out for replacement on my 1975 2 door. I love this idea. Does anyone know if I need to have the front bench seat to get the retractor assembly out? I got it loose but can't seem to wiggle the whole piece out with the seat in the way.
    Also, you say I can send the whole retractor to seatbeltplanet? It appears the retractor is completely encased in a plastic cover that's connected to a metal bracket.
    Thanks in advance for any help!
