Negative cable from battery
Discussion in 'Technical' started by russellgaspard, Aug 5, 2014.
  1. russellgaspard
    russellgaspard Member
    united states
    1973 Ford Maverick 250 Inline 6
    I removed the cable while working on the car and I didnt mark where the other end connected. I know it bolts on somewhere but cant figure out where. Its the main negative cable that runs directly from the battery. Can anyone tell me where I need to connect it?
  2. Craig Selvey
    Engine block
  3. 71gold
    right below the head...
  4. Chlorin8ed
    Chlorin8ed 72 Comet
    Iowa
    1972 Mercury Comet, 1980 Chevy Malibu, 1987 Chevy R10
    I know this is an old thread but... I am looking to replace my negative cable. Hard time finding one that matches it. My neg. cable has a "clamp holder" on it that is clamped directly to the bare wire and then bolted down to the bolt holding the regulator. Does the regulator "need" this direct ground to the battery? If so where does one find a negative battery cable?
  5. Krazy Comet
    Dismal Swamp
    Yes there needs to be a connection from battery to block and another to body... Before Ford took the cheap route and used one cable for both connections, the battery cable connected directly to block with a second smaller cable from block to body... Wheather it's at the regulator or elsewhere makes no difference, but must be a connection to body...
    Maverocket likes this.
  6. Chlorin8ed
    Chlorin8ed 72 Comet
    Iowa
    Thanks for the explanation!
  7. Craig Selvey
    Mustang parts places sell a negative cable like an original. Maybe not "Maverick" original....at least FoMoCo similar.
  8. Chlorin8ed
    Chlorin8ed 72 Comet
    Iowa
    Thanks I will check it out.
  9. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    Melvins sells the original style.
