New 73 Project.
  1. Dave B
    Perfectionist.....or close as I can get.
  2. Dave B
    My friend Mike, came over and held the door, so I could bolt it back on for now, I rebuilt the hinges, it makes a huge difference.
  3. doncomfort
    chillicothe oh
    Its starting to look like something now.
  4. Tannersg1
    Tannersg1 Member
    Classified
    Looks good Dave! Did you replace bushings and pins?
  5. Dave B
  6. Moneymaker 1
    Panama City Florida
    Looking great, It's nice to have help, I had a rough time with my doors but a floor jack and some well placed 2X4's did the trick.
  7. Craig Selvey
    Why not primer the roof?
  8. Dave B
    The roof still needs some work, and it'll be much easier, when it's sitting on it's wheels.
  9. NICK DOMINICK
    Burke, Virginia
    I would have helped if I lived closer. Looks good.
  10. car-nut
    car-nut Glenn
    conn.
    I have the door adjusted just how I want it. Now that it is set, whenever I remove it I just pull the pin. That way every time I install/ uninstall it I know it will go back exactly where I want it.
  11. Dave B
    That will come soon enough, I kinda wanted to get the door, up off the floor for Spring, and hopefully get it primed...(y)
  12. CaptainComet
    I too, have removable pins in in my driver door hinges. I love the idea of lining the door up and being able to pull it and returning it to perfection easily.
    One thing to be careful of is that you need to have the pin installed with the head pointed down on the upper hinge if you want a shot at removing it later.
    Don't know if the passenger hinge has the same requirement. Same-hinge-flipped makes me suspect you might want to look into that. Fortunately, I found out because I had to pull the door soon after I had it back in place. Still burned me up to unbolt the hinge again.
    I don't think my passenger door will ever get rebuilt. It still closes like it is 1972 ... ka-thunk .... It is a beautiful sound. I can only get the driver's door close to sounding that good. But mine started out sounding like a metal trash can getting bounced off the back of a garbage truck. Progress ... a good thing ....
  13. Dave B
    Did some more work on the console, I test fitted it with the shifter hump from the factory floor shift, it stills has about a 1/4" clearance to the bottom of the package tray. Non-floor shift automatics will have roughly 1/2", it's tough to make this fit all cars, but as with anything, with the variances, you may have to do some tweeking.
    If you have me on Facebook, I've posted more pictures there.
  14. mercgt73
    Lookin sharp, Dave! Nice designing.
  15. qpdcqp
    qpdcqp Davon
    Yuba City Ca.
    70 Grabber Maverick, 75 2dr maverick
    Very nice :tiphat:
