New battery progressively DIED
Discussion in 'Technical' started by Hairy W Bush, Nov 30, 2014.
  1. Hairy W Bush
    Hairy W Bush Member
    Georgia
    1972 Maverick Grabber
    yea that's the link we were just talking about. it's a thick wire that goes into the link and then a yellow and black with orange stripe wire comes out. I'll go ahead and make that connection but if the link is bad, how am I going to replace that?
  2. Krazy Comet
    Links can be bought at Advance, AZ, NAPA, etc... Replacements are crimped to wiring (cut out orig link even if good)...
    I believe orig links are 16 gauge, maybe someone knows for sure...
  3. Hairy W Bush
    Hairy W Bush Member
    Georgia
    I have replaced them in the past, but my question to you is how am i going to replace this particular wire?? Like i said it's 1 wire and splits off into 2.
  4. Hairy W Bush
    Hairy W Bush Member
    Georgia
    I went out and looked and the wire pulled out of the connector:slap: I couldn't even tell because of the other wires on the solenoid. Anyway, I used my powerprobe on the 2 wires from that wire and it shows I get continuity on the black wire but not the yellow wire, so I guess this fusible link is toast. I just need a replacement. Could it have blown because of the other wire??
  5. Krazy Comet
    Without actually looking at it no idea how/why problem began... Could have a bare wire someplace or maybe terminal was accidentally shorted to ground, battery reversed etc...
    For crimping the fuse link with two wires get a barrel connector large enough to fit all the wires into... On opposite end with one wire, strip around one inch and fold over in middle so it's a double thickness, insert with link and crimp... I generally solder mine after crimping but in this case the fuse link won't accept solder...
  6. Hairy W Bush
    Hairy W Bush Member
    Georgia
    I'm confused right after you said to fold it so it's double thickness. and do you mean a butt connector?
    I found this picture and was wondering if this could work by using fusible link wire since apparently just part of that fusible link is bad?
  7. Krazy Comet
    Yeah if soldered that repair will work just fine ..
    I meant a butt connector, got up too early up too late, goin' for a shower and bed...
  8. Hairy W Bush
    Hairy W Bush Member
    Georgia
    ok thanks. I was just wondering how this car was able to drive home if I have a problem with both these wires??
  9. Krazy Comet
    Theoretically it should be totally dead with both fuse links open, but obviously there's another path to power at least the ign system... Not knowing your car's mods or past repairs I have no idea(this is what Scooper was referring to)...
    scooper77515 likes this.
  10. Hairy W Bush
    Hairy W Bush Member
    Georgia
    yea i don't know. but thanks for the help guys. I'll make the repair but I still have to replace the starter now :badwords:
