New IL6 installed...Still overheating!?
Discussion in 'Technical' started by Comet4me, Dec 31, 2013.
  1. Comet4me
    Comet4me Member
    1975 Comet
    The PVC valve is inside the chrome breather on the back of the valve cover. The hose is running into the carb somewhere.
  2. Krazy Comet
    That's nice...
    You need a open oil cap on the front so the PCV has some point to draw in fresh air...
  3. Comet4me
    Comet4me Member
    1975 Comet
    Oh? Ok I didn't realize that? I'll need to look for an open oil cap then too.
  4. Comet4me
    Comet4me Member
    1975 Comet
    I just popped off the rear PVC breather cap and shook out what looks like dirty apple sauce. Smells like oil. Aerated oil maybe. Would that happen as a result of not having a breather cap on the front of the valve cover? Is this a good clue?
  5. 71gold
    I fire my new engines with straight distilled water and no T-stat.
    does your T-stat have air bleed holes?
  6. Comet4me
    Comet4me Member
    1975 Comet
    I don't know if t-stat has holes or not.
  7. Comet4me
    Comet4me Member
    1975 Comet
    I'm thinking the aeration is causing the problem now. But I know the oil level was correct and not too full, so I don't understand why the oil would aerate. Unless it's because I'm missing the filtered cap as mentioned earlier by Krazy. My wife said she noticed that the oil pressure was low after the overheat.
  8. blugene
    Appla sauce? Did you pull the dip stick and look at that? Sounds like condensation. Is there vacuum to the pcv?
  9. Comet4me
    Comet4me Member
    1975 Comet
    Dipstick oil looked normal
  10. Comet4me
    Comet4me Member
    1975 Comet
    Happy new year
  11. blugene
    Happy new year.
    Not having a shroud is a factor to consider even if not THE problem at this time. How about timing? Is the cap holding pressure? I am assumming so if it got to 240 and you didn't see alot of steam?
  12. Comet4me
    Comet4me Member
    1975 Comet
    Yeah cap is good. No problem there.
  13. blugene
    How does the balancer look? Maybe timing is off?
  14. Comet4me
    Comet4me Member
    1975 Comet
    Idk. I'll have to check out the balancer in the morning
  15. blugene
    Yawwwnn.. K.. Good luck.
