New Kicks
Discussion in 'General Maverick/Comet' started by GRABTHIS73, Mar 26, 2021.
  1. GRABTHIS73
    GRABTHIS73 Member
    reno nv
    1973 maverick
    I have a 73 maverick and I'm wondering if I can put on a set of 235 mm wide tires without complications?
  2. Hotrock
    Munroe Falls, Ohio
    Welcome to the forum!!!
    You did not provide us much information. Are you asking about all four wheels or just the rear? I run 255x15s on the rear. Other members are running 275x15s on the rear. Wheel dimension is the determining factor. Back spacing is critical. I have 15x8 wheels with 4 1/4" back spacing. Some members are using 15x8 with 4 1/2" back spacing.
    There are a number of wheel and tire combinations listed in the Garage section of this site under wheels and tires.
    Good luck with your Maverick.
  3. 71gold
    :Welcome:...:Handshake:
    Pep Boyz
    GLS 275X60X15 on 8" rims.
    GRABTHIS73 likes this.
  4. GRABTHIS73
    GRABTHIS73 Member
    reno nv
    1973 maverick
    I'm looking at all 4, it looks like the front can handle it, I'm concerned about the tires hitting the inside of the fenderwell on a hard turn. I'm thinking of suiting it up with 235 65 14s
  5. 71gold
    who makes this tire?
    235 65 14s
  6. TeeEl
    TeeEl Senior Member
    Colorado
    You need the right wheel back-spacing. I had 235/60-14s for years, but I don't know if they're made in that size anymore. When I ran 15s, they were 215/60-15 up front, and 235/60-15 in back. You don't want much more than 25-inch diameter up front (maybe 25-1/2")...
  7. GRABTHIS73
    GRABTHIS73 Member
    reno nv
    1973 maverick
    I meant 235 60 14
  8. GRABTHIS73
    GRABTHIS73 Member
    reno nv
    1973 maverick
    Thanks for the info, does the 215 work on a 8 inch rim?
  9. 71gold
    the tire specs should give you a width range.
    mine now are 255x60x15 on 8" rims (back).
    215x60x15 on 6" rims (front).
    a rim too wide will bulge the sidewall.
    my 275x60x15 would rub on 10" rims but not on 8".
  10. GRABTHIS73
    GRABTHIS73 Member
    reno nv
    1973 maverick
    Ah, good to know. Now I can't wait to get some tires on this thing! Got a set of flower mags
