...new motor acted a fool...
Discussion in 'Technical' started by 71gold, Apr 2, 2007.
  1. M.A.V.
    M.A.V. Yep,my real initials.
    Macon,Georgia
    Derrick, he has the car running now...see the first post in this thread.;)
  2. Maverick Man
    California
    doh... ok i'm stupid...
  3. dkstuck
    dkstuck Member
    Latrobe Pa (Pgh)
    72 Maverick in drag
    Ground your engine real good! That means somewhere on that pretty engine you'll have to scrape paint
  4. 71gold
    with no grounds you shouldn't get voltage through a ...rubber hose..
    ...:D ...
  5. 69 ina 1/2
    69 ina 1/2 Fox body nut!!!
    Smog Bernardino, Ca.
    This is wierd but this article says that electrolysis may be to blame. Could be b.s. but interesting never the less. Read the part where it says "Sometimes the path of least resistance is a radiator or heater hose".
    http://www.radiatorreporter.com/electrol.html. :hmmm: .
  6. Rick Book
    Rick Book Member
    Thailand
    Missing my old '70 Maverick
    Interesting article. Thx!
    Electrolysyisisysi damaged both my AFR (aluminum) heads. I do not like electolsyriszcs. I do not like electrolysicsxc at all.
  7. Hawkco
    Hawkco Genuine Car Nut
    Rex, Georgia (GA)
    77 Maverick
    Rick, you are either desirous of having a little one in the house or you're really starting to miss all those brain cells that left during your misspent youth.:16suspect
  8. 71gold
    ...guess what i found 3 days ago...tube-to-header joint leak...in my rad. i just had press. tested before i installed it.:yup:
    this stuff is spooky...
    i know what i am doing tomorrow...
    i even put an extra ...braided...ground strap on my new motor when i installed it after talking to Rick.
    at least now we can keep a check on things and maybe keep it from doing it again...thanks for the ..link
    a friend of mine had already suggested to put one on the bellhousing for the starter. i have an extra one from when i bought my first one. i guess i will keep ...grounding...untill my ...rad. hose is volt free.
    see...i won't :coco: after all.
    thanks again
    ...:bouncy: ...
  9. 71gold
    thanks for the tip...:Handshake
  10. Grabber5.0
    Grabber5.0 Gear-head wannabe
    Kansas City, MO
    71 Grabber
    I think I detect a little seriousness there. :p What did it do to them? I tried searching, but you post too much. :D
  11. 71gold
    ...when you find that post you will see what i don't want to happen to mine...
    ...:bouncy: ...
  12. Rick Book
    Rick Book Member
    Thailand
    Electrlyosisioso caused major pitting on the bottom surface of my heads - large enough pits that it might be the reason my head gaskets blew (that, and running too low of octane). ref: http://mmb.maverick.to/showthread.php?t=28491&page=4&highlight=pitting
