New motor installed, HELP ME...HELP ME...
Discussion in 'Technical' started by psyweezle, Dec 29, 2008.
  1. obmav
    obmav Greg Garrison
    olive branch, ms
    partial owner/ 1973 Maverick
  2. SeanC
    SeanC Member
    Vegreville, alberta,Canada
    1972 comet GT
    Get the number off the cam. He may have used the 351w cam which is the opposite firing order to what you used. Early 302s and 289s used the 28oz balancer and if your engine has the 86 internals(crank and rods) you need to have the 50oz balancer and flexplate. But if it were the balancer you would still be able to set the timing. Does it ever pop through the carb. If so this would indicate the engine being retarded way too far. Just some stuff I have run across. Good luck. Make sure your vacuum advance is hooked to the right spot too. For now unhook it all together.
  3. Dave B
    Did anyone put a vacuum gauge on it and see what it was reading?
  4. darren
    Took the words right out of my mouth. I was just reading through to see if anyone suggested that. There it is the last post. Go figure. A vacuum gauge can save hours of wasted time. If its valve lash you'll see it. Very erratic.
  5. Scoot110703
    Scoot110703 Member
    Huntsville, AL
    1973 Maverick - 2dr I6
    I don't know if this is your problem but on my wife's car a couple years ago, her motor started idling really high and it ended up being the intake manifold gasket. After we relpaced that, it ran great....
  6. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    Did we ever find the problem?
    I'm dying to hear what it was...
  7. cdeal28078
    cdeal28078 Member
    North Carolina
    71 F100
    I am betting on a 351w cam and wrong firing order myself. Maybe the throttle is hanging up on the base plate gasket or the secondaries are adjusted too tight.
    Why is the distributor running through a relay? Is it just the 12v feed running though it? Just curious
    clint
