new motor start up ???
Discussion in 'Technical' started by 71gold, Mar 15, 2009.
  1. 71gold
    #1...yes
    #2...no
    #3...yes
    #4...yes
    #5...new
    #6...dry
    #7...maybe
    #8...thanks
    ...:Handshake...
  2. 71gold
    yes...a great idea...:bananaman
  3. 71gold
    you can delete this....it ain't going to happen...:naughty:
    ...LFF...
  4. 71gold
    from what i have read on...washer fluids...this is the correct fluid to use at this heat range.
    ...:yup:...
  5. 71gold
    yes...low temp is what i have...
    ...:Handshake...
  6. 71gold
    it must be something Major...
    ..Effie came out and it wouldn't start for her...
    she seems to think it must ne something i did...:huh:
    she said..."it ran the last time she road in it"...:yup:
    ...:cry:...
  7. rthomas771
    Are you using washer fluid or blinker fluid? They come in the same bottle the only difference is the color of the label...one is purple and the other is violet
  8. 71gold
    ...blinker fluid is thick and oily...:yup:
    ...and you need to wake your socks up about 8:00AM tomorrow...:bouncy:
    ...JFF...:bouncy:
  9. yellow75
    Tillamook Oregon
    Must be the infamous flux capacitor causing the problem, now if you can just find out were it is in the car
  10. Dan Starnes
    Dan Starnes Original owner
    West Central IL
    You gots to have air, fuel and spark. Have you added any of that to your window wash tank? You stated you had spark, do you have spark to your plugs? Does a plug spark out of the head when grounded to something? I had a problem like that back in the stone age. Turned out to be a massive vaccum leak caused by me when installing the intake manifold. Have you bought a can of air, fuel, spark at summit?
    Dan
  11. ford84stepside
    ford84stepside Lone Wolf
    Berry Alabama
    1947 Lincoln Zephyr Coupe
    I think your whatamcallit that bolts to the doohickey on the thingamajig that controls the whatizt that makes the goofball do the jig when you work the skyhook on the dobobble with you foot is loose. You're going to have to reverse the sinew and tighten up the skiskabob on the left turnbuckle 1/4 turn and it will fire right up!
  12. markso125
    markso125 Member
    Lewiston Ut
    1972 maverick 2 door LDO
    Ohh it might be you have negative polarity plug wires and you need to have the positive polarity ones for your spark plugs... Yes you must go to summit and Baby Jane's and that should put things properly into perspective.:thumbs2:
  13. CornedBeef4.6L
    CornedBeef4.6L no longer here
    no longer here
    Sorry Frank.....I could send one of our alcoholic members down to try this method out for you.....:dance:
  14. CornedBeef4.6L
    no longer here
    if you want it deleted I can do that for you sir...it was all in fun....:(:D
    FFL:bananaman
  15. Dave B
    Hey, I've got my own engine to start up, I just don't have time...:D
