new motor start up ???
Discussion in 'Technical' started by 71gold, Mar 15, 2009.
  1. 1970mavinator
    1970mavinator Member
    Ruskin, FL
    1970 2dr I6 maverick
    Wow tough crowd out there!! What did you do to piss him off Jeff?:rofl2:
  2. cdeal28078
    cdeal28078 Member
    North Carolina
    71 F100
    If you are using an MSD box do you have the RPM pill installed? Don;t ask me how I know that one. lol
    clint
  3. daydreamer
    daydreamer Mavmenace
    Oshawa, Ontario
    1972 Ford Maverick
    hey i know what the problem is. its the owners fault. Plug him in and see if he sparks:rofl2:
  4. Blown74
    Blown74 Member
    Va
    74 302 blown- 68 Shelby Gt 500- 69 Cougar XR7 428 ram air
    washer bottle??
    Comeon guys... look, it has nothing to do with your washer bottle.. Do you have fire at the plugs??? You said you had it at the dizzy and coil. If its firing at the plugs (ignition-wise) does the car even try to start or does it just spin over? If you have fuel and spark to the cylinders, it should fire at least, maybe not start , but fire. Have you checked your firing order at the dizzy? Is the dizzy in correct position? (not 180*out) Are you getting any kind of ignition at all? :huh:
  5. daydreamer
    Oshawa, Ontario
    1972 Ford Maverick
    hey did you acually screw the plugs into the heads or are they still in the box??????????????:idea:
  6. Jamie Miles
    Alto, GA
    I've had a few
    Probably left the rotor button out of the distributor.
  7. maverick1970
    maverick1970 MCG State Rep
    Missouri
    That is what I originally thought. But I figured that Frank was much smarter than that.:rolleyes: :D
    I am sure that is the first thing Effie checked!
  8. sierra grabber
    sierra grabber Certifiable
    northern nevada
    its like the first time you light the barbeque, pour gas all over the top of it and throw the match on. then when the block warms up enough it will run....:biglaugh:
  9. darren
    You may be closer than you think. I remember the 302 in my first Mav. 11.5: 1 with a very healthy cam and heads. We tried for an hour to get it running. Checked #1 and dist. , Spark, fuel. Pulled plugs and they were dry. OK its not a flooded engine. Lets think about it. Its 60 degrees outside with no choke and a big open single plane intake. Lets load her up. About 9 full throttle squirts and it fired up and scared the hell out us. Its 10 pm in the driveway with open headers. Of course I ran it through the cam break in at fast idle. My Mom and Dad were really pissed and a few of the neighbors. Around 11 the cops showed up while were having a few beers to celebrate. They were pretty cool. They loved the car and had me fire it up to check the noise level. They just laughed and told me it sounded great but dont go running down the road like that or your busted. Sorry to jump in on your post but its a good story.:bananaman Talk about being proud when that motor fired. Took me 3 years to build it.
    PS I was around 20 years old in case you were wondering why I ran open headers at 10 PM. DUH
  10. Wilbur Green
    Wilbur Green Member
    Plymouth, Ohio
    76Stallion, 762dr.
    Frank, you running a 6AL or something like it, on the blue car had trouble with it not starting sometimes just quit running sometimes ended up being ground from box to block fouling it , cleaned up block had paint under ground fixed problem.
  11. 71gold
    ...just not getting any spark from...coil...dist...at plugs...
    i changed out the coil and still nothing...
    i have 12V of power to the coil/dist...no box...
    i think we have it down to the dist.:yup:
    going back to Summit with Jeff tomorrow and see if we can get it straightened out...then to Baby Jane's for lunch...:thumbs2:
    i'm going to put the ...washer bottle...on in the morning...;)
    thanks for all the comments and if you think of anything else please post...
    ...Ya'll Friend Frank...:Handshake
  12. 1970mavinator
    Ruskin, FL
    I might be crazy, but it appears that everybody was trying to bring humor to the situation.:huh:
  13. M.A.V.
    M.A.V. Yep,my real initials.
    Macon,Georgia
    Good Call !:yup:
    Now back on topic......:deadhorse
  14. 71gold
    i think being everything under the hood is new, i'll just get me a ...new bottle washer...at Summit tomorrow for my car...:bananaman
    ...:tiphat:...
  15. rthomas771
    That's Mike's job...he is use to it. :D
