New motor
Discussion in 'Drag Racing' started by pro stock, Jun 29, 2016.
  1. dan gregory
    dan gregory Member
    chesapeake va
    1970 maverick
    Looks like you are going to have some fun,GREAT!
  2. Craig Selvey
  3. 71maverick361
    71maverick361 Vern Isaac
    Odem
    71 Grabber
    Nice looking Mav and great times
  4. mcknight77
    mcknight77 Member
    Boise, ID
    74 Mav drag car, 1970 Maverick, 1971 Bronco, 66 Nova, 67 Ranchero
    Love those Clevelands! Tell some more about the engine.
  5. pro stock
    pro stock Member
    1973 maverick
    NASCAR crank&rods 13 1/2 to one 70 4bar heads victor intake re worked holly 1050 cfm roller cam 670 lntake 670 exh roller rockers 1"7/8 headers 3" exh mighty mite c4 full rollerized 8" converter 4800 stall
  6. mcknight77
    mcknight77 Member
    Boise, ID
    I'm starting the build of a 351C for my son's Cougar so I have a couple dozen questions for you Pro Stock:
    Where did you source the NASCAR crank and rods?
    What kind of fuel are you using for 13.5:1 CR with iron heads?
    What pistons are you using?
    Jim
  7. pro stock
    pro stock Member
    1973 maverick
    Bryant crank 3.75 Carrillo rods 5.85 diamond Pistons boss 351 block 30 over have filled I know a some guys at roush racing
  8. pro stock
    pro stock Member
    1973 maverick
    Renegade fuel
  9. pro stock
    pro stock Member
    1973 maverick
    Had to cut 150 off the crank so the piston would clear
  10. pro stock
    pro stock Member
    1973 maverick
    Heads 4v 1970 not much done just cleaned up titanium valves int&exh and retainers with pac spings
  11. pro stock
    pro stock Member
    1973 maverick
    I am surprised how much low end this motor has when I took it to the track I left at 1100 rpms and only shifted it at 6500 I shirted in to 3rd 100' before the finish line in the 1/8 so it's got a lot more in her working this week getting it to hook up and go from there
  12. pro stock
    pro stock Member
    1973 maverick
    Yea milled a 100 off the heads
  13. mcknight77
    mcknight77 Member
    Boise, ID
    "I know a some guys at roush racing"
    That sure is helpful!
  14. bossmav
    bossmav Drag racing nut
    Harrisonburg, Va
    74 Grabber now Pearl white
    Oh brother talk about a tight fit... You can turn a wrench my friend! Where to you find the shoe horn to get that bad boy down in there ;-) You now have a lot more motor than rear, a 9 inch and lower gears would do you a lot of good.
    Good luck and keep racing!
  15. dan gregory
    dan gregory Member
    chesapeake va
    1970 maverick
    They actually say that a Cleveland works better than a Windsor because the exhaust ports tilt lower for a better fit.Through the years there have been quite a few racers with 351c engines in these cars,& they have won a lot too,Rickey Smith comes to mind.
