New problem, engine will not turn over at all...
Discussion in 'Technical' started by sac240, Apr 3, 2007.
  1. sac240
    sac240 Member
    sacramento, ca
    70 mav
    Well, its probably got all of 40 degrees of motion either way before it stops, I will try the tranny thing though, that sounds easy enough, I did spin it for the two bumps before I put it in, so we'll have to see, any other ideas. Thanks guys.
  2. 71gold
    Don, he would have had to turn the motor to put the bolts in to start with...:huh:
    i blew a front pump from not seating a C4 once...:yup:
    ...:bouncy: ...
  3. don graham
    not if you work the way i do, frank.:hmmm:
  4. Rocco
    Rocco Member
    Chicago, IL
    1977 Maverick
    Pull the valve covers. If all looks good you could try to loosen the rockers so all the valves will be closed (which would eliminate the valve-to-piston interference). If you can turn the motor freely, you have found the problem, if it still binds its not the valves. Are you running a mechanical fuel pump, because it cound be a possibitity too.
