New reproduction fan shroud
Discussion in 'General Maverick/Comet' started by MCCI, Sep 12, 2017.
  1. 72Cometsedan
    72Cometsedan Member
    Georgia
    1972 Comet 4 door sedan 302 1973 Maverick 4 door sedan 200
    Be careful with the fit before you buy the D1DZ-8146AKT shroud. The part number on my shroud is D0DZ-8146B. I ordered a D1DZ-8146AKT, it being the only one I can find on the web. This shroud 'does not' work on my Non-AC 302 Comet. It does fit the radiator but the tunnel does not extend back far enough, and the fan blades are exposed behind the shroud. See picture to compare the two shrouds.
    Cheers,
    72Cometsedan
    Ronald Hopkins likes this.
  2. Craig Selvey
    I would say the shroud would still provide some benefit.
    One could also get a longer fan spacer that would place the fan inside the "tunnel".
    dyent and Shorty like this.
  3. 72Cometsedan
    72Cometsedan Member
    Georgia
    Yes indeed. I installed a 3" spacer from Allstar Performance; part number 30192. Thanks for the tip. I also replaced the 4-blade rigid fan with a 5-blade flexible blade fan from the trusty parts stash.
  4. Jaybee
    Jaybee Member
    Hampton Roads, VA
    1974 Maverick
    There you go, you won't have any trouble with that.
