New Stroker Builds this Winter
Discussion in 'Technical' started by rotorr22, Sep 15, 2015.
  1. rotorr22
    rotorr22 Member
    Columbiana, Ohio
    That is a really popular build and for good reason. Most choose the 274 or the 282 roller.
  2. mojo
    Seems to me from what u have listed, you already have a pretty nice setup. But, I suppose, since you have the blocks -- why not! That XE 274 mostly suited for manual shift cars?
  3. 351Blueblood
    351Blueblood Member
    To be announced
  4. bmcdaniel
    Nope, his car is an automatic. The XE274HR is probably the most popular off-the-shelf cam for 331/347 strokers with limited lift valve springs. Past that most would get a custom cam ground.
    I've had two 347s in my car in the past, broke both of them. Swore that if I ever wanted more displacement again I would just do a 351 or 408. But I do have those two blocks in the shed...
  5. rotorr22
    rotorr22 Member
    Columbiana, Ohio
    Were the two failures related to the same issue?
  6. bmcdaniel
    Possibly, I'm thinking the blocks didn't like the combination of added stroke and a 150 hp shot of nitrous. If I do another one I wouldn't use a power adder. Those days are past...
  7. JoeB
    JoeB Member
    Stowe, PA
    71 Maverick, 72 Comet GT
    Had this built for me earlier this year...hope to get it in tomorrow, but you know what they say...Man plans, Henry Ford laughs. I found out the hard way the oil pan was 1/16" too wide, had 3/8" cut off each side, time to try again
    Block-Dart 9.5 SHP 427cid 4.125bore X 4.00stroke
    Crank- K1 4340 forged 4.00stroke
    Rods-K1 4340 forged H-beam 6.250
    Pistons- SRP flat tops w/valve relief
    Cam-Crower custom grind 113°lobe separation
    duration @.05 Int. 240° Ext. 246°
    Lift .584 .560
    Heads-AFR 195 with 72cc chamber
    Intake-Edelbrock Super Victor
    Carb-Quick Fuel Black Diamond Q-850
    351Blueblood likes this.
  8. bmcdaniel
    Just curious, why such a wide LSA?
  9. JoeB
    JoeB Member
    Stowe, PA
    bmc, I told the builder(Doug Meyers of Automotive Machining Services) that I was not interested in a big lumpy idle. That being said he went into a long and in depth explanation concerning valve overlap, air speed, and LSA. He gave a "thumper" cam as an example 107° LSA....please do not think that my eyes did not glaze over during this...Anyway Doug does a lot R&D with Crower, his business is all word of mouth advertising, and he has been building fast Fords for 35+ years, so I let him spec the cam(he knows more than me). Motor produced 564 hp at 6000 and was 561 at 6500 on the dyno . I got the motor installed yesterday, hopefully I'll get the tranny in today. A couple more weeks an I should be able to go play
  10. groberts101
    groberts101 Member
    Minneapolis, MN
    I was going to ask the exact same thing myself. His builders response to this question was the ONLY reasoning I could possibly imagine.
    I'm very confused as to how the peak torque is @ higher rpm than the peak horsepower. This doesn't compute and I can only assume some numbers or memory cells got swapped around. Not to mention peak torque at that high rpm isn't physically possible with that little cam either. I would have to guess that peak torque would be much closer to 4,500 rpm.
    In the end.. 564 horses with torque to spare over a narrower powerband vs 590 horsepower and slightly more torque spread over a wider rpm with plenty to spare is overkill for this light little car anyways. Sounds like it'll be a blast to drive. Hope he's got enough rear rubber meeting the road! :evilsmile:
  11. JoeB
    JoeB Member
    Stowe, PA
    My bad with the numbers, both numbers are hp...
