New to forum, wanted to share my budget build!
Discussion in 'Maverick/Comet Projects' started by ktm525gp, Jan 12, 2012.
  1. olerodder
    olerodder Member
    NorCal
    Just a couple of things here.............first I would put screw in studs, your pressed in studs are not going to hold up to over .500 lift of the F cam. Also, if you are going to run the F then you should buy the springs that go with the cam, or have a machine shop shim the springs you currently have to meet the spec's of the installed height and closed and open pressure..............this is pretty important. My guess is that the windsor springs ARE worn out, and I wouldn't use them. Really the installed height is what you need to determine and you need to know the spring tension at installed height and open. A machine shop can tell you this. Never put used springs on a new cam without having them checked out.............especially when the cam is over .500 lift. I think even the E303 is still around .498 lift, so switching to a smaller lift cam really won't accomplish anything because you still don't know what kind of springs you have and if they are up to spec with the cam.
    As for maximum lift of the heads, that really depends on the valve train you are using, springs, retainers, keepers and screw in studs..............deep six those pressed in studs............if you pulled a stud you could probably kiss the motor good buy as it would turn it into scrap. Also, I would clay the tops of the pistons to see how much clearance you have when the cam is at full lift..........just to see how much room you still have between the valve and top of piston, just to be safe.................IMHO
  2. olerodder
    olerodder Member
    NorCal
    Talking about the C90E heads, I don't think you can run a mechanical cam without milling pedestal and installing screw in studs.
    I had a set on my 64 289HiPro Comet and remember I went through a lot of hassle to put them on. I had a wild Schiefer cam ( .540 lift) and back in 1970 there weren't too many guys playing around with that much lift on the street.
    Also, I think you are going to have to go with regular rockers, not the stock type. It's been about 40 years ago since I play'd around with 351w heads, but they sure did wake up the little 289..............with 4:56 gears in the 9" there weren't too many cars that could catch me in one stoplight.
  3. ktm525gp
    ktm525gp Member
    Riverside, CA
    1971 Ford Maverick
  4. Red1972Grabber
    Northern California
    Sounds good! (y)
  5. ktm525gp
    ktm525gp Member
    Riverside, CA
    1971 Ford Maverick
    update///floor
    Well motor is runnung perfect. ive ran it the last few days. havent had to touch anything, not getting hot, checked the plugs again, everything is looking good. tomarrow i get my car up onto the lift and ill be putting the motor and tranny in. finish the exaust make my mounts for the seats, put my center hump ebrake in, and hook up shift lincage. looks like ill be driving this thing in a few more days, road worthy probably in a couple more weeks. did the floor today.
    first pick is the ho;e driverside floor. same as passenger side.
    second pic is the rust spots
    third pic. i grinded down to bare metal, primed it.
    fourth used por 15 to seal the rust up.
  6. ktm525gp
    ktm525gp Member
    Riverside, CA
    1971 Ford Maverick
    update
    so motor is in. headers are on. made my tranny mount. dot the measure ments for the driveshaft. so in a few more days we will be out on the road. ill have pics soon.
  7. ktm525gp
    ktm525gp Member
    Riverside, CA
    1971 Ford Maverick
    update
    so since the floor was done. motor got put in. headers are on. made my battery mount in the trunk. made my tranny mount. put the shifter in. put my center ebrake system in. just gotta plum and wire up the motor. get the drive shaft shortend a bit. hopefully take it for a spin this weekend. also got my brake caliper brackets made. well the aluminum ones. gotta ake the steel ones this next week or the following.
  8. jayss10
    jayss10 This is Minerva
    INDIANA
    1971 MAVERICK,73 GRABER CLONE
    Nice car buddy welcome aboard
  9. ktm525gp
    ktm525gp Member
    Riverside, CA
    1971 Ford Maverick
    havent been on in awhile, left you all hanging
    here you go. c4 to aodto t5 5 speed. to sets of 69 head to aluminum, to different intakes. mini spool in the nine inch, granada discs in front, all brandnew suspension up front, new bfgs, weld wheels, fenders doors, havent put the grabber stuff on yet cause waiting for it to come back from being dipped,front bumper, rear bumper, 69 mustang bucket seats, battery relocation, the lst goes on and on. its so nice to put gas in the car and drive it. it is now officially reliable. posting pics now.
  10. ktm525gp
    ktm525gp Member
    Riverside, CA
    1971 Ford Maverick
    pics of progress since last on to now
    tfs aluminum heads, there 170, ported the crap out of them the last pic is the 351w 69 heads ported itty bitty
  11. ktm525gp
    ktm525gp Member
    Riverside, CA
    1971 Ford Maverick
    heads and intake
    ported intake ports and match ported the intakes. even headers had to be done
  12. ktm525gp
    ktm525gp Member
    Riverside, CA
    1971 Ford Maverick
    body
    waiting for my grabber stuff to come in so i can get the car started on body work. there out getting dipped. so i got my hole front end on,bumper filler piecs,fenders,doors. all these parts i scored so i can save my self time to do the body work.
  13. ktm525gp
    ktm525gp Member
    Riverside, CA
    1971 Ford Maverick
    1 year of owning the car
    t5 swap was very easy, easier then doing the aod swap. didnt like the aod cause it didnt have the quick response that i was looking for. even with 350 gears and a mini spool. motor didnt like it either. went to the junkyard found a forxbody with a good driveshaft fit perfect with a c4 yoke and ford 9 inch. if i would of known that it was cheaper then the aod swap i would of never put it in. just need to start doing the frame connect, get my caltrac bars on, and off to irwindale. if i can get it to hook hoping for mid 10s. i cant wait. then i can start making my jig to get the strut front end made so i can get steering angle for drift nights down at the local track. then i can get the 4 link done in the rear. stay tuned. this time next year itll be crazzier then it is now.
  14. listlesssleeper
    listlesssleeper New Member
    1972 Ford Maverick
    Im from so cal as well. Nice ride!
