New vs. Turned
Discussion in 'Wheels and Tires' started by tmcbride415, Apr 25, 2015.
  1. tmcbride415
    tmcbride415 Member
    1972 Ford Maverick 200 Strait 6
    Should I turn my existing brake drums for $20 each or should I just buy new ones for $30?
    The car is a 1972 Ford Maverick and has original brake drums but are quite rusted and need to either be sanded/painted and turned, or replaced.
  2. mojo
    I think I would replace if they need all you have mentioned. Any amount of metal removed from the drum will decrease ability to dissipate heat. Also, how do you know the drums on the car have not been turned b4 you got it. Go w/ new for the xtra 10 bucks and save yourself the trouble --- IMO.
  3. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    Have you had the old drums checked for minimum thickness? If they are too thin, they can't be turned.
    I think for 10 bucks more, I'd just get new ones. Paint them with high-heat engine enamel so they'll look good & not rusr.
    I like Duplicolor engine paint. You don't need brake caliper paint for the rear drums. The engine paint will work just fine.
  4. Craig Selvey
    I would still have the new drums turned to make sure they are "true".
    71gold, Crazy Larry and rthomas771 like this.
  5. 71gold
    :Welcome:...:Handshake:
    where are you getting the drums for $30?
  6. junrai
    junrai Member
    rancho cordova ca
    if all it is is $10 difference I wouldnt even consider it throw the old ones out and put new ones on
    Crazy Larry likes this.
