newbie need alot of help
Discussion in 'Technical' started by GITRDONE15, Mar 12, 2010.
  1. 71gold
    #3. engine mount stands...
    7. stock 302 manifolds from a MAVERICK
  2. GITRDONE15
    GITRDONE15 Member
    i think i might be into this cheaper then i thought i was going to be....
  3. Mavman72
    Front sump oil pan and pick up tube.
    Front cover with dipstick tube provision
    (explorer has dipstick in the block) will be problematic in a mav with headers.
  4. GITRDONE15
    GITRDONE15 Member
    im just going to run stock manifolds
  5. Mavman72
    Must be "Maverick" 302 manifolds. Nothing else fits manifold wise.
  6. scooper77515
    Frank corrected my terminology. I meant the metal part of the engine mounts. They are relatively hard to find. The rubber part of the engine mount you can get for $15 at AutoZone.
  7. GITRDONE15
    GITRDONE15 Member
    you guys think i should get a tranny thats mounts up or do the mods to make that bolt to my C4 in the car now....you think that would be the best way out?....what you guys do if you were presented this motor and car?
  8. GITRDONE15
    GITRDONE15 Member
    whats really giving me a hard time is what bell housing to use for this....i didnt know you could switch bell housing on an auto c4.....what vechile would i have to get that from to bolt up to my c4.....the 98 block is whats throwing me off
  9. PaulS
    Get the bell housing that fits the block and the flex plate to balance the ebgine. Any C4 bell housing will bolt to your C4 as long as it is a case fill and not a pan fill but you want a small bell V-8 bell housing to fit your engine and the flex plate has to have 157 teeth. The balance of the flex plate has to match the engine balance.
    All 302 and 351 bell housings will bolt to the engine - if it is a small bell it will bolt ti the front pump area of your transmission.
