Newbie
Discussion in 'New Members Forum' started by stumanchu, Feb 2, 2016.
  1. stumanchu
    stumanchu Stuart
    Portland, OR
    WP_20160206_13_21_26_Pro (2).jpg WP_20160206_13_22_02_Pro (2).jpg WP_20160206_13_18_48_Pro[1].jpg WP_20160206_13_21_26_Pro (2).jpg WP_20160206_13_22_02_Pro (2).jpg WP_20160206_13_18_48_Pro[1].jpg Some pics of project. The more I look at it, the more I want a parts car.
    Paul Masson likes this.
  2. 71maverick361
    71maverick361 Vern Isaac
    Odem
    71 Grabber
    Nice it don't look bad. Great project car keep us posted
  3. Krazy Comet
    You have a Maverick hood... What about grille & bumper??
  4. stumanchu
    stumanchu Stuart
    Portland, OR
    grille and bumper are both maverick. Someone ditched the big bumpers and used maverick stuff. If I get a comet parts car, I will keep the hood and grille and swap back when I find a skinny bumper.
  5. stumanchu
    stumanchu Stuart
    Portland, OR
    The trunk had a bad leak in it and started to rust from the inside out. The batt
    ery box is gone and the core support by it has a lot of rust....but the rest of it is rust free for the most part.
  6. NCFatBoy
    NCFatBoy Member
    Raleigh, NC
    1973 Ford Maverick
    Welcome!
  7. junrai
    junrai Member
    rancho cordova ca
    looks really straight. reminds me of the blue 74 we had
    we had so much fun in that car even though it was a rust bucket. I remember you could see the freeway under our feet lol
  8. racing ranger
    racing ranger Member
    Iowa
    72 Comet GT Boss Powered, 83 Ranger S/G, 94 F250 Styleside 4x4, 2007 Ford Focus SES
    :thumbs2: Welcome from central Iowa
  9. stumanchu
    stumanchu Stuart
    Portland, OR
  10. stumanchu
    stumanchu Stuart
    Portland, OR
    forgot to take pic under the hood! No bell housing = no starter. I dont even know if it runs. I really want to crank it!
  11. 71gold
    why not just put a Maverick tailpanel on it...:thumbs2:
  12. Gene Fiore
    Gene Fiore Member
    Goodyear, AZ
    Welcome aboard!
  13. stumanchu
    stumanchu Stuart
    Portland, OR
    As the rain in Portland subsides a bit, I have been able to pull the plastic off the car and begin to figure out what is needed under the hood. I bought the car as an unfinished 302 swap, and I inherited all the dead ends of the previous owner(s). I took the pulleys out of the trunk to see if they fit. The crank pulley fits, the water pump pulley hits the crank pulley. I write down part #s and discover I have a '65 crank pulley and a '72 6 cyl water pump pulley. I also notice that my lower radiator hose port on the radiator is on the wrong side, and the top port looks like it will never make it to the Tstat housing without the weirdest hose known to man. The engine code tells me I have a 1971 "torino" 302. I go to pick&pull ( 3 miles away) to see what I see.....only 1 pre 50 oz. SBF in the whole yard (I have read enough posts to know the 28 oz vs 50 oz 302 schemes), a 1976 van with a 351. I also notice the water pump inlet is driverside.....hmmmmm. It has a PS pump of the GM style with a bracket that bolts to the water pump, and I think...hmmmmm. So, I get the water pump, WP pulley, Tstat housing (which turns up 90 degrees and looks like a hose would actually work on my car with it) power steering pump and bracket. That night at home, I learn some of the differences between 60s and 70s SBFs, of which the 302 in my car happens to be a mix of. Today I went back for the lower pulley and harmonic balancer, but ruined it with my steering wheel puller......oops. Other parts collected to date: 1980 Granada disc brake spindles,rotors,calipers,p-valve, C4 (car had a 250 with 164 tooth flex plate and A servo) block plate,cooling lines, speedo cable, From maverick in WA P&P: drive shaft,grille, Ebrake cables (mine were cut), hood prop, Other misc items: black steering wheel,throttle cable & bracket, mustang bucket seats, tailight housing driverside (thanks Steve) keys from the locksmith, And a ton of stuff from Rock Auto waiting for installation. I almost have enough junk to make one car!!!!!! This is fun, but the work is waiting....
