Newbies Considering a V8 Swap, Looking for Advice
Discussion in 'General Maverick/Comet' started by chuth, Jan 12, 2020.
Tags:
  1. chuth
    chuth Member
    Lebanon, OH
    1973 Maverick
    Thanks!
  2. chuth
    chuth Member
    Lebanon, OH
    1973 Maverick
    I've read that headers are a tight fit. What headers will fit? My sons car has power steering and is column shift. Thanks!
  3. 71gold
    what engine and heads did you decide on?
  4. chuth
    chuth Member
    Lebanon, OH
    1973 Maverick
    We bit the bullet and bought an engine. It was just pulled out of a restored pick-up truck. The engine was in the truck when the owner bought it a couple of years ago and he hadn't done much to it or knew much history on it. He'd been saving for a new engine to put in and finally had all the parts to go ahead and pull the old one. The block has an E6SE casting, so 1986, roller lifters. It seems somebody already converted it from EFI to a carb. Not sure on the heads, I'm thinking they are E7. The harmonic balancer has a 1972 date code on it. image0.jpeg
  5. ike72com
    ike72com Member
    Charleston SC
    Here iz where the fun starts! You got a mixture of parts. You best have a plan my friend.
    71gold likes this.
  6. ike72com
    ike72com Member
    Charleston SC
  7. Krazy Comet
    If it has ¾" reach spark plugs, has the asthmatic E6 heads(Crown Vic, Fox T-Bird etc). E7 uses ½" reach plugs.
    With '72 on harmonic balancer it should be a 28oz balance engine.
  8. 71gold
    strip it down to the crank, find out what bottom end you have and build it up from there..or Summit.
    ATK High Performance 1968-74 Ford 302 Stock Drop-In Long Block Crate Engines HP99F
    JMO
    mojo and ike72com like this.
  9. ike72com
    ike72com Member
    Charleston SC
    Thats what I was thinking too 71Gold.
    Buying an old motor thats been sitting is a core expecting to be rebuilt.
    I recalled Newbies is on a tight budget.
  10. Krazy Comet
    You guys like to spend someone else's money...
  11. 71gold
    "a tight budget"
    that just means it takes longer to do it right...:yup:
    mojo likes this.
  12. mojo
    Either way you go in this hobby, it's going to cost you money. Going w/ unknown engine, sitting for "who knows how long" is all-right if one is looking to hone their skills on rebuilds. However, if you're looking for less chance of having too do things more than once -- odds are much better going w/ plan B.
    It comes down too what ones mechanical skill/knowledge levels, and what they can perform as oppose to what has to be farmed out -- what the ultimate money outlay will be...
    TeeEl and 71gold like this.
  13. xpsnake
    xpsnake Bruce
    Maryville, IL (near STL)
    1971 Ford Maverick 2-door
    Hooker 6901 will clear, and if you search the forum there are a number of other popular brands, but you'll need to modify your column shifter rods or do a Granada cable swap. I've attached photos of each. With power steering, you will also need a power steering drop bracket.
  14. chuth
    chuth Member
    Lebanon, OH
    1973 Maverick
    Thank you! All this is so helpful. This is a great forum!
  15. chuth
    chuth Member
    Lebanon, OH
    1973 Maverick
    The oil pan that came with this engine appears to be a larger capacity pan than what would have been stock in 73. Does anybody know if this pan will fit in the 73 without any interference? Thanks. oil pan1.jpeg oil pan2.jpeg
